Datasheet VERSA-PAC (Eaton) - 3
ManufacturerEaton
DescriptionInductors and Transformers (Surface Mount)
Pages / Page9 / 3 — Product specifications- notes. VERSA-PAC. PCM. Dimensions- mm. NOTES:. …
Product specifications- notes. VERSA-PAC. PCM. Dimensions- mm. NOTES:. max. ref
Product specifications- notes VERSA-PAC PCM Dimensions- mm NOTES: max ref
VP Technical Data 4301 VERSA-PAC® Inductors and Transformers (Surface Mount) Effective August 2017
(1) The first three or four digits in the part number signify the size of the (8) Maximum Energy capability of each winding. This is based on 30% package. The next four digits specify the AL, or nanoHenries per turn saturation of the core: squared. -R indicates RoHS compliant. (2) 1 L Energy = S2 BASE = Nominal Inductance of a single winding. SERIES x x 0.7LBASE x I2SAT(BASE) 2 (3) IBASE is the lessor of ISAT(BASE) and IRMS(BASE). 1 (4) Peak current that will result in 30% saturation of the core. This Energy = P2 PARALLEL x x 0.7L 2 BASE x I2SAT(BASE) current value assumes that equal current flows in all six windings. For applications in which all windings are not simultaneously driven For multiple windings, the energy capability varies as the square of (i.e. flyback, SEPIC, Cuk, etc.), the saturation current per winding the number of windings. For example, six windings (either parallel may be calculated as follows: or series) can store 36 times more energy than one winding. 6 x I I SAT(BASE) SAT = Number of Windings Driven (9) Thermal Resistance is the approximate surface temperature rise (5) RMS Current that results in a surface temperature of approximately per Watt of heat loss under still-air conditions. Heat loss is a 40 °C above ambient. The 40 °C rise occurs when the specified combination of core loss and wire loss. The number assumes the current flows through each of the six windings. underlying PCB copper area equals 150% of the component area. (6) Maximum DC Resistance of each winding. (7) For multiple windings in series, the volt-µsecondTOTAL (µVs) capability (10) These devices are designed for feed-forward applications, where varies as the number of windings in series (S): load current dominates magnitizing current. Volt-µsec = S TOTAL x Volt-µsec(BASE)
VERSA-PAC
temperature rise depends on total power losses and For multiple windings in parallel, the volt-µsecondTOTAL (µVs) capability size. Any other
PCM
configurations other than those suggested is as shown in the table above. could run hotter than acceptable. Certain topologies or applications must be analyzed for needed requirements and matched with the best
VERSA-PAC
size and configuration. Proper consideration must be used with all parameters, especially those associated with current rating, energy storage, or maximum volt-seconds.
VERSA-PAC
should not be used in off-line or safety related applications. The breakdown voltage from one winding to any other winding is 500 VAC maximum.
Dimensions- mm
VP1 and VPH1 TOP VIEW RECOMMENDED PCB LAYOUT WHITE DOT N PIN #1 LOGO (OPTIONAL) 1 12 M P D VPH 1 12 (10PLCS) (12 PLCS) _- A K _ _ COMPONENT _ J (12PLCS)
NOTES:
_ 0 SIDE (10PLCS) 6 7 1)Tolerances A - I are ± 0.25 mm unless specified 6 7 otherwise. B L 2)Tolerances J - P are +/- 0.1 mm unless specified (12PLCS) otherwise. C 4 10 3)Marking: a)Dot for pin #1 identification FRONT VIEW b) VP(H)x-xxx (product code, size, 4 digit part number per family table.) 1 7 c) Versa Pac Logo (optional) E 5 11 d) wwl yy = (date code) R = (revision level) 4)Al soldering surfaces must be coplanar within 0.102 mm. 2 8 5)Packaged in tape and reel 600 parts per reel F 6 12 I G H (12 PLCS) (2 PLCS) 3 9 WWLLYY R 1:1:1:1:1:1
A B E F G H I J K L M N O P mm mm mm mm mm mm mm mm mm mm mm mm mm mm mm mm max ref max ref ref max ref ref ref ref ref max
VP1 and VPH1 12.9 9.2 13.0 0.7 5.9 6.2 1.5 0.1 0.25 11.5 1.5 2.25 9.7 14.2 2.0 0.5 www.eaton.com/electronics 3
