Datasheet VERSA-PAC (Eaton) - 5
ManufacturerEaton
DescriptionInductors and Transformers (Surface Mount)
Pages / Page9 / 5 — Dimensions- mm. NOTES:. max. ref
Dimensions- mm NOTES: max ref
VP Technical Data 4301 VERSA-PAC® Inductors and Transformers (Surface Mount) Effective August 2017
Dimensions- mm
VP4 and VPH4 M L TOP VIEW O WHITE DOT (10PLCS) PIN #1 1 12 J 1 12 COMPONENT I (12PLCS) N D SIDE VPH_-_ _ _ _ (10PLCS) (12 PLCS) LOGO A 6 7 (OPTIONAL)
NOTES:
K (12PLCS) 6 7 1) Tolerances A - I are ± 0.25 mm unless specified 1 4 otherwise. B 2) Tolerances J - P are +/- 0.1 mm unless specified otherwise. C 3)Marking: 12 9 a)Dot for pin #1 identification 2 5 b) VP(H)x-xxx (product code, size, 4 digit part FRONT VIEW number per family table.) c) Versa Pac Logo (optional) d) wwl yy = (date code) R = (revision level) 11 8 4)Al soldering surfaces must be coplanar within E 3 6 0.102 mm. 5) Bulk packaged H For tape and reel add TR to part number: (i.e. G (12 PLCS) F (2 PLCS) (12 PLCS) VP4-0140TR-R) 140 parts per reel 10 7 1:1:1:1:1:1
A B C D E F G H I J K L M N O mm mm mm mm mm mm mm mm mm mm mm mm mm mm mm max ref max ref max ref ref ref ref ref max
VP4 and VPH4 18.0 18.0 24.6 0.7 10.0 3.3 0.1 0.4 14.25 1.75 3.43 19.14 26.0 2.5 0.75 VP5 and VPH5 M L TOP VIEW O WHITE DOT (10PLCS) PIN #1 1 12 J 1 12 COMPONENT I (12PLCS) N D SIDE VPH_-_ _ _ _ (10PLCS) (12 PLCS) LOGO A 6 7 (OPTIONAL) K (12PLCS)
NOTES:
6 7 1 4 1) Tolerances A - I are ± 0.25 mm unless specified B otherwise. 2) Tolerances J - P are +/- 0.1 mm unless specified C otherwise. 12 9 3)Marking: 2 5 a)Dot for pin #1 identification FRONT VIEW b) VP(H)x-xxx (product code, size, 4 digit part number per family table.) c) Versa Pac Logo (optional) 11 8 d) wwl yy = (date code) R = (revision level) E 3 6 4)Al soldering surfaces must be coplanar within 0.102 mm. H 5) Bulk packaged G (12 PLCS) F (2 PLCS) For tape and reel add TR to part number: (i.e. (12 PLCS) 10 7 VP5-0155TR-R) 115 parts per reel 1:1:1:1:1:1
VP5 and VPH5 21.0 21.0 28.5 0.7 10.8 2.95 0.1 0.4 17.25 2.25 3.15 22.7 29.0 3.0 0.75 www.eaton.com/electronics 5
