Datasheet VERSA-PAC (Eaton) - 6
ManufacturerEaton
DescriptionInductors and Transformers (Surface Mount)
Pages / Page9 / 6 — How to use multiple windings. VERSA-PAC. PCM. Series Connected. Parallel …
How to use multiple windings. VERSA-PAC. PCM. Series Connected. Parallel Connected
How to use multiple windings VERSA-PAC PCM Series Connected Parallel Connected
Technical Data 4301 VP Effective August 2017 VERSA-PAC® Inductors and Transformers (Surface Mount)
Discrete inductors combine like resistors, when connected in series or parallel. For example, inductors in series add and inductors in parallel reduce in a way similar to Ohm’s Law. L = L1 + L2 + L3...Ln Series L = 1/ [1/L1 + 1/ L2 + 1/ L3..1/Ln] Parallel Windings on the same magnetic core behave differently. Two windings in series result in four times the inductance of a single winding. This is because the inductance varies proportionately to the square of the turns. Paralleled
VERSA-PAC
windings result in no change to the net inductance because the total number of turns remains unchanged; only the effective wire size becomes larger. Two parallel windings result in approximately twice the current carrying capability of a single winding. The net inductance of a given
PCM
configuration is based on the number of windings in series squared multiplied by the inductance of a single winding (LBASE). The current rating of a
PCM
configuration is derived by multiplying the maximum current rating of one winding (IBASE) by the number of windings in parallel. Examples of simple two-winding devices are shown below:
Series Connected
(2 Windings)
Parallel Connected
(2 Windings) 10µH 1 Amp 10µH 10µH 1 Amp 1 Amp 10µH 1 Amp L = L x S2 I = I x P L = L x S2 I = I x P TOTAL BASE MAX BASE TOTAL BASE MAX BASE = 10 µH x 22 = 1 Amp x 1 = 10 µH x 12 = 1 Amp x 2 = 40 µH = 1 Amp = 10 µH = 2 Amps Where: LBASE = Inductance of a single winding P = Number of windings in parallel (use 1 with all windings in series) S = Number of windings in series IBASE = Maximum current rating of one winding 6 www.eaton.com/electronics
