Datasheet TLP3412SRH (Toshiba)
Manufacturer | Toshiba |
Description | Photorelay (MOSFET output, 1-form-a) |
Pages / Page | 14 / 1 — TLP3412SRH. Photocouplers. Photorelay. TLP3412SRH. 1. Applications. … |
File Format / Size | PDF / 437 Kb |
TLP3412SRH. Photocouplers. Photorelay. TLP3412SRH. 1. Applications. (Note). •. ATE. (Automatic. Test. Equipment). •. Probe. Cards. •. Measuring
TLP3412SRH Photocouplers Photorelay TLP3412SRH 1. Applications (Note) • ATE (Automatic Test Equipment) • Probe Cards • Measuring Instruments • High-Speed Logic IC Testers • High-Speed Memory Testers Note: The product(s) described herein should not be used for any other application. 2. General The TOSHIBA TLP3412SRH is a very small outline non-leaded photorelay suitable for surface-mount assembly. It is housed in a S-VSON4T package.TLP3412SRH has a Built-in input resistor, which eliminates an external input resistor for space saving. Its features include low off-state current and low output pin capacitance. 3. Features (1) S-VSON4T: 2.0 (L) mm × 1.45 (W) mm × 1.3 (H) mm (2) Normally opened (1-Form-A) (3) OFF-state output terminal voltage: 60 V (min) (4) Operating voltage: 3 V (max) (5) ON-state current: 400 mA (max) (6) ON-state resistance: 1 Ω (typ.), 1.5 Ω (max) (7) Isolation voltage: 500 Vrms (min) 4. Packaging and Pin Assignment 1: Anode 2: Cathode 3: Drain 4: Drain 11-2E2 Start of commercial production 2019-05 ©2018-2019 1 2019-05-20 Toshiba Electronic Devices & Storage Corporation Rev.2.0
