Datasheet Teseo-LIV3R (STMicroelectronics) - 8
DescriptionTeseo ROM GNSS module
Pages / Page30 / 8 — Supported GNSS constellations. Teseo-LIV3R. 2.1 GPS. 2.2 GLONASS. 2.3 …
File Format / SizePDF / 864 Kb
Supported GNSS constellations. Teseo-LIV3R. 2.1 GPS. 2.2 GLONASS. 2.3 BeiDou
Supported GNSS constellations Teseo-LIV3R 2.1 GPS 2.2 GLONASS 2.3 BeiDou
Supported GNSS constellations Teseo-LIV3R 2 Supported GNSS constellations
The embedded FW supports the following GNSS constellations (GPS, GLONASS, BEIDOU and QZSS). The user can select what the application needs by FW configuration. GPS+GLONASS are selected by default.
2.1 GPS
The Teseo-LIV3R GNSS module is designed to receive and to track the L1C/A signals provided at 1575.42 MHz by the Global Positioning System (GPS). The Teseo-LIV3R can receive and process GPS concurrently with GLONASS or BeiDou (the last two are mutually exclusive).
2.2 GLONASS
The Teseo-LIV3R module can receive and process GLONASS concurrently with GPS. The Russian GLONASS satellite system (ГЛОНАСС; GLObal NAvigation Satellite System) is an alternative to US’s GPS.
2.3 BeiDou
The Teseo-LIV3R module can receive and process BeiDou concurrently with GPS. B1 signals provided at 1561.098 MHz by the BeiDou Navigation Satellite System can be tracked by Teseo-LIV3R positioning modules. The ability to receive and track BeiDou B1 satellite signals in conjunction with GPS results in higher coverage, improved reliability and better accuracy especially in the difficult urban environment of the big far east cities like Shanghai, Taipei, and Singapore. 8/30 DS12821 Rev 2 Document Outline Table 1. Device summary 1 General description 1.1 GNSS performance Table 2. GNSS performance 1.2 Block diagram Figure 1. Teseo-LIV3R block schematic 1.3 Pin configuration Figure 2. Teseo-LIV3R pin layout 1.4 Pin out description Table 3. Teseo-LIV3R pin out description 2 Supported GNSS constellations 2.1 GPS 2.2 GLONASS 2.3 BeiDou 3 Augmentation systems 3.1 Satellite-Based augmentation system 3.2 QZSS 3.3 Differential GPS Table 4. Supported RTCM message on Teseo-LIV3R 4 Assisted GNSS 4.1 RealTime AGNSS 5 Clock generation 5.1 Temperature-Compensated Crystal Oscillator (TCXO) 5.2 Real Time Clock (RTC) 6 I/O interfaces 6.1 UART 6.2 I2C 7 FW configuration 8 Power mode 8.1 Hardware standby 8.2 Software standby 9 Geofencing 10 Odometer 11 Regulatory compliance 11.1 CE certification for Teseo-LIV3R Figure 3. CE marking 12 Electrical characteristics 12.1 Parameter conditions 12.2 Minimum and maximum values 12.3 Typical values 12.4 Absolute maximum ratings Table 5. Voltage characteristics Table 6. Thermal characteristics Table 7. Power consumption 12.5 Recommended DC operating conditions Table 8. Recommended DC operating conditions 13 Mechanical specifications Figure 4. Teseo-LIV3R mechanical specification 14 Shipping information 14.1 Reels Figure 5. Carrier tape Figure 6. Teseo-LIV3R orientation Figure 7. Cover tape Figure 8. Plastic reel Figure 9. PB band 14.2 Packing cartons for reels 14.3 ESD handling precautions 14.4 Moisture sensitivity levels 15 Labeling information Figure 10. Labeling information of Teseo-LIV3R Table 9. Labeling information description 16 Reflow soldering profile Table 10. Soldering profile values Figure 11. Soldering profiles 17 ECOPACK® Appendix A Reference document Revision history Table 11. Revision history
