Datasheet LTC5582 (Analog Devices) - 5
Description | 40MHz to 10GHz RMS Power Detector with 57dB Dynamic Range |
Pages / Page | 18 / 5 — TYPICAL PERFORMANCE CHARACTERISTICS. VCC = 3.3V, EN = 3.3V, TC = 25°C, … |
Revision | A |
File Format / Size | PDF / 621 Kb |
TYPICAL PERFORMANCE CHARACTERISTICS. VCC = 3.3V, EN = 3.3V, TC = 25°C, RT1 = 0Ω,
link to page 10 LTC5582
TYPICAL PERFORMANCE CHARACTERISTICS VCC = 3.3V, EN = 3.3V, TC = 25°C, RT1 = 0Ω, RT2 = 0Ω unless otherwise noted. Test circuits shown in Figure 1. Output Voltage vs RF Input Power Linearity Error vs RF Input Power Supply Current vs Supply Voltage
2.8 3 60 TC = 25°C TC = 25°C 2.4 2 50 2.0 1 TAGE (V) 1.6 Y ERROR (dB) 0 40 Y CURRENT (mA) 1.2 450MHz –1 450MHz OUTPUT VOL 880MHz LINEARIT 880MHz T SUPPL C = 125°C 2140MHz 2140MHz 30 TC = 105°C 0.8 2700MHz –2 2700MHz TC = 85°C 3800MHz 3800MHz TC = 25°C 5800MHz 5800MHz TC = –40°C 0.4 –3 20 –65 –55 –45 –35 –25 –15 –5 5 –65 –55 –45 –35 –25 –15 –5 5 2.6 2.8 3.0 3.2 3.4 3.6 3.8 RF INPUT POWER (dBm) RF INPUT POWER (dBm) SUPPLY VOLTAGE (V) 5582 G01 5582 G02 5582 G27
Output Voltage, Linearity Error vs Output Voltage Temperature Linear Error vs RF Input Power, RF Input Power, 450MHz Variation from 25°C, 450MHz Modulated Waveforms, 450MHz
2.8 3.0 3.0 3 TC = 125°C TC = 25°C TC = 105°C 2.4 2.0 2.0 TC = 85°C 2 LINEARIT TC = –40°C 2.0 1.0 1.0 1 TAGE (V) Y ERROR (dB) T ERROR (dB) 1.6 0 0 Y ERROR (dB) 0 1.2 –1.0 TURE DRIF –1.0 –1 OUTPUT VOL TC = 125°C T LINEARIT C = 105°C 0.8 TC = 85°C –2.0 –2.0 –2 4-CARRIER WCDMA T TEMPERA C = 25°C CW TC = –40°C 3-CARRIER CDMA2K 0.4 –3.0 –3.0 –3 –65 –55 –45 –35 –25 –15 –5 5 –65 –55 –45 –35 –25 –15 –5 5 –65 –55 –45 –35 –25 –15 –5 5 INPUT POWER (dBm) INPUT POWER (dBm) RF INPUT POWER (dBm) 5582 G3 5582 G04 5582 G05
Output Voltage, Linearity Error vs Output Voltage Temperature Linear Error vs RF Input Power, RF Input Power, 880MHz Variation from 25°C, 880MHz Modulated Waveforms, 880MHz
2.8 3.0 3.0 3 T T C = 125°C C = 25°C TC = 105°C 2.4 2.0 2.0 TC = 85°C 2 LINEARIT TC = –40°C 2.0 1.0 1.0 1 TAGE (V) Y ERROR (dB) T ERROR (dB) 1.6 0 0 Y ERROR (dB) 0 1.2 –1.0 TURE DRIF –1.0 –1 OUTPUT VOL TC = 125°C T LINEARIT C = 105°C 0.8 TC = 85°C –2.0 –2.0 –2 4-CARRIER WCDMA T TEMPERA C = 25°C CW TC = –40°C 3-CARRIER CDMA2K 0.4 –3.0 –3.0 –3 –65 –55 –45 –35 –25 –15 –5 5 –65 –55 –45 –35 –25 –15 –5 5 –65 –55 –45 –35 –25 –15 –5 5 INPUT POWER (dBm) INPUT POWER (dBm) RF INPUT POWER (dBm) 5582 G6 5582 G7 5582 G08 Rev A For more information www.analog.com 5 Document Outline Features Applications Description Typical Application Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Typical Performance Characteristics Pin Functions Test Circuits Applications Information Package Description Revision History Typical Application Related Parts Features Applications Typical Application Description Absolute Maximum Ratings Order Information Electrical Characteristics Pin Configuration Typical Performance Characteristics Pin Functions Test Circuits Applications Information Package Description Revision History Typical Application Related Parts
