Datasheet AD7124-4-EP (Analog Devices) - 9
Description4-Channel, Low Noise, Low Power, 24-Bit, Sigma-Delta ADC with PGA and Reference
Pages / Page17 / 9 — Enhanced Product. AD7124-4-EP. Parameter1 Min. Typ. Max. Unit. Test. …
File Format / SizePDF / 247 Kb
Enhanced Product. AD7124-4-EP. Parameter1 Min. Typ. Max. Unit. Test. Conditions/Comments
Enhanced Product AD7124-4-EP Parameter1 Min Typ Max Unit Test Conditions/Comments
POWER-DOWN CURRENTS13 Independent of power mode Standby Current IAVDD 7 15 μA LDOs on only IIOVDD 8 20 μA Power-Down Current IAVDD 1 3 μA IIOVDD 1 2 μA 1 Temperature range = −55°C to +125°C. 2 These specifications are not production tested but are supported by characterization data at the initial product release. 3 FS is the decimal equivalent of the FS[10:0] bits in the filter registers. 4 The integral nonlinearity is production tested in full power mode only. For other power modes, the specification is supported by characterization data at the initial product release. 5 Following a system or internal zero-scale calibration, the offset error is in the order of the noise for the programmed gain and output data rate selected. A system full- scale calibration reduces the gain error to the order of the noise for the programmed gain and output data rate. 6 Recalibration at any temperature removes these errors. 7 Gain error applies to both positive and negative full-scale. A factory calibration is performed at gain = 1, TA = 25°C. 8 When gain > 1, the common-mode voltage is between (AVSS + 0.1 + 0.5/gain) and (AVDD − 0.1 − 0.5/gain). 9 Specification is for a wider common-mode voltage between (AVSS − 0.05 + 0.5/gain) and (AVDD − 0.1 − 0.5/gain). 10 REJ60 is a bit in the filter registers. When the first notch of the sinc filter is at 50 Hz, a notch is placed at 60 Hz when REJ60 is set to 1. This gives simultaneous 50 Hz and 60 Hz rejection. 11 When the gain is greater than 1, the analog input buffers are enabled automatically. The buffers can only be disabled when the gain equals 1. 12 When VREF = (AVDD − AVSS), the typical differential input equals 0.92 × VREF/gain for the low and mid power modes and 0.86 × VREF/gain for full power mode when gain > 1. 13 The digital inputs are equal to IOVDD or DGND with excitation currents and bias voltage generator disabled. Rev. 0 | Page 9 of 17 Document Outline FEATURES ENHANCED PRODUCT FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM TABLE OF CONTENTS REVISION HISTORY GENERAL DESCRIPTION SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS OUTLINE DIMENSIONS ORDERING GUIDE
