Datasheet AD7992 (Analog Devices)
Description2-Channel, 12-Bit ADC with I2C Compatible Interface in 10-Lead MSOP
Pages / Page1 / 1 — 2 Channel, 12-Bit ADC with I2C. Compatible Interface in 10-Lead MSOP. …
RevisionA
File Format / SizePDF / 53 Kb
2 Channel, 12-Bit ADC with I2C. Compatible Interface in 10-Lead MSOP. Errata Sheet. AD7992. SCL. AGND. SDA. TOP VIEW. ALERT. IN2 / REFIN
Datasheet AD7992 Analog Devices, Revision: A
a
2 Channel, 12-Bit ADC with I2C Compatible Interface in 10-Lead MSOP Errata Sheet AD7992
Please be advised that it was necessary to change the pin-out diagram for the AD7992 ADC. Please discard any pin-out information from AD7992 data sheets up to and including Rev PrF. Packaged material may be identified by the date code; parts with date code 0321 have the old pin-out and will be no longer manufactured. All other date-coded material will be manufactured according to the new pin-out diagram shown below. CONVST 1 10
SCL AGND
2
AD7992
9
SDA V TOP VIEW
3 8
DD ALERT
(Not to Scale)
V
4 7
AGND IN2 / REFIN VIN1
5 6
AS
REV. A Sept 2003 Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rights of third parties
which may result from its use. No license is granted by implication or
Tel: 781/329-4700 World Wide Web Site: http://www.analog.com
Fax: 781/326-8703 Analog Devices, Inc., 2003
