LTC6228 0.88nV/√Hz 730MHz, 500V/µs, Low Distortion Rail-to-Rail Output Op Amp with Shutdown FEATURESDESCRIPTION n Ultra Low Voltage Noise: 0.88nV/√Hz The LTC®6228 is a very fast, low noise rail-to-rail output, n Low Distortion at High Speeds: unity gain stable op amp. It has a gain-bandwidth product of HD2/HD3 < −100dBc (Av = +1, 4V 890MHz and a slew rate of 500V/μs. The low input referred P-P, 2MHz, RL = 1k Ω ) n High Slew Rate: 500V/μs voltage noise of only 0.88nV/√Hz and low distortion pefor- n mance of better than −100dB at 4V GBW = 890MHz P-P even for large signals n as fast as 2MHz make it ideal for applications that require –3dB Frequency (AV = +1): 730MHz n high dynamic range and deal with high slew rate signals, Input Offset Voltage: 250μV Max Across Temperature n such as driving A/D converters. Additional features include Offset Drift :0.4μV/°C Shutdown and the ability to enable/disable internal bias cur- n Input Common Mode Range Includes Negative Rail rent cancellation to optimize noise performance. n Output Swings Rail-to-Rail n Supply Current: 16mA/Channel Typ The combination of low offset, low offset drift, high gain n Shutdown Supply Current = 500µA and high CMRR make the LTC6228 the superior choice n for wide dynamic range applications. Operating Supply Range: 2.8V to 11.75V n Large Output Current: 80mA Min The LTC6228 family maintains excellent performance for n Very High Open Loop Gain: 5.6V/μV (135dB), RL = 1kΩ supply voltages of 2.8V to 11.75V and the devices are n Operating Temp Range: –40°C to 125°C specified at supplies of 3V, 5V and 10V(±5V). n Package Options: 8-Lead SOIC, TSOT-23, DC-6 With an input range extending to the negative rail and an output range that encompasses the entire supply range, APPLICATIONS the operational amplifier can accommodate wide swinging n signals, and single supply operation. Optical Electronics: Fast Transimpedance Amplifiers n Driving High Dynamic Range A/D Converters For space constrained PCB layouts, the LTC6228 is avail- n Active Filters able in a 2mm × 2mm DFN. It is also available in conven- n Video Amplifiers tional leaded packages. n High Speed Differential to Single-Ended Conversion These amplifiers can be used as improved replacements n Low Voltage Hi-Fi Amplification for many high speed op amps to improve speed, noise, All registered trademarks and trademarks are the property of their respective owners. distortion and dynamic range. TYPICAL APPLICATIONSystem Performance: 2 x LTC6228 Driving LTC2387-188192 Point FFT, –1dBFSLTC6228 Based Driver for the LTC2387-18 SAR ADCfSMPL = 15Msps, fIN = 1MHz 0 7.3V 7.5V P-P 1MHz INPUT SIGNAL SNR = 93.4dB 4.096V + –20 SFDR = 95dB CLK LTC6228 THD = –93.8dB 0V DCO –40 LVDS – 25Ω IN+ DA INTERFACE –60 82pF DB –80 LTC2387-18 82pF TWOLANES AMPLITUDE (dBFS) –100 4.096V + IN– TESTPAT 25Ω VCM PD –120 LTC6228 0.1µF 0V SAMPLE – CNV REFB CLOCK –140 –2.5V 0 0.5 1 1.5 2 2.5 3 3.5 4 4.5 5 5.5 6 6.5 7 7.5 FREQUENCY (MHz) 6228 TA01a 6228 TA02 Rev 0 Document Feedback For more information www.analog.com 1 Document Outline Features Applications Typical Application Description Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics (VS = ±5V) Electrical Characteristics (VS = 5V, 0V) Electrical Characteristics (VS = 3V, 0V) Typical Performance Characteristics Pin Functions Applications Information Typical Applications Package Description Typical Application Related Parts
