Datasheet LTC6228 (Analog Devices) - 5
Description0.88nV/√Hz 730MHz, 500V/µs, Low Distortion Rail-to-Rail Output Op Amp with Shutdown
Pages / Page26 / 5 — ELECTRICAL CHARACTERISTICS (V. The. denotes the specifications which …
ELECTRICAL CHARACTERISTICS (V. The. denotes the specifications which apply over the. S = ±5V)
ELECTRICAL CHARACTERISTICS (V The denotes the specifications which apply over the S = ±5V)
LTC6228
denotes the specifications which apply over the S = ±5V) full operating temperature range, otherwise specifications are at TA = 25°C. VS = ±5V,VCM = 0V, VSHDN = floating unless otherwise noted. SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
FPBW Full Power Bandwidth VOUT = 8VP-P, AV = +2, THD < –40dBc 12.5 MHz HD2/HD3 Harmonic Distortion, RL = 1kΩ to Half Supply, fC = 100kHz, VO = 4VP-P –113/–119 dBc AV = +1 fC = 100kHz, VO = 2VP-P –126/–131 dBc fC = 1MHz, VO = 4VP-P –107/–114 dBc fC = 1MHz, VO = 2VP-P –119/–132 dBc fC = 5MHz, VO = 4VP-P –83/–96 dBc fC = 5MHz, VO = 2VP-P –90/–113 dBc fC = 10MHz, VO = 2VP-P –74/–89 dBc Harmonic Distortion, RL = 100Ω to Half fC = 100kHz, VO = 4VP-P –105/–106 dBc Supply, AV = +1 fC = 100kHz, VO = 4VP-P –118/–124 dBc fC = 1MHz, VO = 4VP-P –97/–107 dBc fC = 1MHz, VO = 2VP-P –100/–114 dBc fC = 5MHz, VO = 4VP-P –79/–75 dBc fC = 5MHz, VO = 2VP-P –83/–82 dBc fC = 10MHz, VO = 2VP-P –72/–68 dBc ΔG Differential Gain (NTSC) AV = 2, RL = 150Ω 0.008 % AV = +1, RL = 1kΩ 0.001 % Δθ Differential Phase (NTSC) AV = 2, RL = 150Ω 0.004 Deg AV = +1, RL = 1kΩ 0.09 Deg
denotes the specifications which apply S = 5V, 0V) over the full operating temperature range, otherwise specifications are at TA = 25°C. VS = 5V, 0V,VCM = VOUT = 2.5V, VSHDN = floating unless otherwise noted. SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
VOS Input Offset Voltage –105 20 105 μV l –290 290 μV TCVOS Input Offset Voltage Drift l 0.4 μV/°C IB Input Bias Current (Note 6) Bias Cancellation Disabled –40 –16 μA l –44 μA Bias Cancellation Enabled –3 1 3 μA l –4.4 4.4 μA IOS Input Offset Current Bias Cancellation Disabled –0.55 0.1 0.55 μA l –0.8 0.8 μA Bias Cancellation Enabled –0.9 0.15 0.9 μA l –1 1 μA en Input Noise Voltage Spectral Density f = 1MHz 0.88 nV/√Hz Integrated 1/f Noise 0.1Hz to 10Hz 0.94 μVP-P in Input Current Noise Spectral Density f = 1MHz Bias Cancellation Disabled 3 pA/√Hz f = 1MHz Bias Cancellation Enabled 6.3 pA/√Hz CIN Input Capacitance Differential Mode 3.5 pF Common Mode 1.5 pF RIN Input Resistance Differential Mode 2.6 kΩ Common Mode 4 MΩ AVOL Large Signal Voltage Gain RL = 1kΩ to Half Supply, VOUT = VCM ±2 120 140 dB l 115 dB RL = 100Ω to Half Supply, VOUT = VCM ±2 106 120 dB l 100 dB CMRR Common Mode Rejection Ratio VCM = V– – 0.1 to V+ – 1.2V 97 110 dB l 92 dB Rev 0 For more information www.analog.com 5 Document Outline Features Applications Typical Application Description Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics (VS = ±5V) Electrical Characteristics (VS = 5V, 0V) Electrical Characteristics (VS = 3V, 0V) Typical Performance Characteristics Pin Functions Applications Information Typical Applications Package Description Typical Application Related Parts
