LTC6228 ELECTRICAL CHARACTERISTICS (VThe l denotes the specifications which applyS = 5V, 0V)over the full operating temperature range, otherwise specifications are at TA = 25°C. VS = 5V, 0V,VCM = VOUT = 2.5V, VSHDN = floatingunless otherwise noted. SYMBOL PARAMETERCONDITIONSMINTYPMAXUNITS SR Slew Rate AV = +4, 4V Output Step (Note 8) 350 V/μs FPBW Full Power Bandwidth VOUT = 4VP-P, AV = +2, THD < –40dBc 18 MHz HD2/HD3 Harmonic Distortion, RL = 1kΩ to Half Supply fC = 100kHz, VO = 2VP-P –106/–130 dBc fC = 1MHz, VO = 2VP-P –95/–105 dBc fC = 5MHz, VO = 2VP-P –88/–114 dBc fC = 10MHz, VO = 2VP-P –78/–90 dBc Harmonic Distortion, RL = 100Ω to Half fC = 100kHz, VO = 2VP-P –112/–115 dBc Supply fC = 1MHz, VO = 2VP-P –99/–120 dBc fC = 5MHz, VO = 2VP-P –83/–88 dBc fC = 10MHz, VO = 2VP-P –70/–73 dBc ΔG Differential Gain (NTSC) AV = 2, RL = 150Ω 0.005 % AV = +1, RL = 1kΩ 0.002 % Δθ Differential Phase (NTSC) AV = 2, RL = 150Ω 0.007 Deg AV = +1, RL = 1kΩ 0.018 Deg ELECTRICAL CHARACTERISTICS (VThe l denotes the specifications which applyS = 3V, 0V)over the full operating temperature range, otherwise specifications are at TA = 25°C. VS = 3V, 0V,VCM = 1.5V, VSHDN = floating unlessotherwise noted. SYMBOL PARAMETERCONDITIONSMINTYPMAXUNITS VOS Input Offset Voltage –110 24 110 μV l –300 300 μV TCVOS Input Offset Voltage Drift l 0.4 μV/°C IB Input Bias Current (Note 6) Bias Cancellation Disabled –38 –16 μA l –44 μA Bias Cancellation Enabled –3.5 1.5 3.5 μA l –4.3 4.1 μA IOS Input Offset Current Bias Cancellation Disabled –0.55 0.1 0.55 μA l –0.8 0.8 μA Bias Cancellation Enabled –0.9 0.15 0.9 μA l –1 1 μA en Input Noise Voltage Spectral Density f = 1MHz 0.88 nV/√Hz Integrated 1/f Noise 0.1Hz to 10Hz 0.94 μVP-P in Input Current Noise Spectral Density f = 1MHz Bias Cancellation Disabled 3 pA/√Hz f = 1MHz Bias Cancellation Enabled 6.3 pA/√Hz CIN Input Capacitance Differential Mode 3.5 pF Common Mode 1.5 pF RIN Input Resistance Differential Mode 2.6 kΩ Common Mode 4 MΩ AVOL Large Signal Voltage Gain RL = 1kΩ to Half Supply, 118 130 dB (VOUT = VCM ±1V) l 113 dB RL = 100Ω to Half Supply, 120 dB (VOUT = VCM ±1V) CMRR Common Mode Rejection Ratio VCM = V– to V+ – 1.2V 95 110 dB l 91 dB VCMR Input Common Mode Range l V– – 0.1 V+ – 1.2 V Rev 0 For more information www.analog.com 7 Document Outline Features Applications Typical Application Description Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics (VS = ±5V) Electrical Characteristics (VS = 5V, 0V) Electrical Characteristics (VS = 3V, 0V) Typical Performance Characteristics Pin Functions Applications Information Typical Applications Package Description Typical Application Related Parts
