Datasheet LTC6228 (Analog Devices) - 10
Description | 0.88nV/√Hz 730MHz, 500V/µs, Low Distortion Rail-to-Rail Output Op Amp with Shutdown |
Pages / Page | 26 / 10 — TYPICAL PERFORMANCE CHARACTERISTICS. VS = ±5V, VCM = 0V, TA = 25°C, … |
File Format / Size | PDF / 2.5 Mb |
TYPICAL PERFORMANCE CHARACTERISTICS. VS = ±5V, VCM = 0V, TA = 25°C, unless otherwise noted. VOS vs Temperature, 10V Supply
LTC6228
TYPICAL PERFORMANCE CHARACTERISTICS VS = ±5V, VCM = 0V, TA = 25°C, unless otherwise noted. VOS vs Temperature, 10V Supply VOS vs Temperature, 5V Supply VOS vs Temperature, 3V Supply
160 160 160 VS = ±5V VS = ±2.5V VS = 3V, 0V 140 VCM = 0V 140 VCM = 0V 140 VCM = 1.5V 5 DEVICES 5 DEVICES 5 DEVICES V) 120 V) 120 V) 120 TAGE (µ 100 TAGE (µ 100 TAGE (µ 100 80 80 80 60 60 60 40 40 40 INPUT OFFSET VOL INPUT OFFSET VOL INPUT OFFSET VOL 20 20 20 0 0 0 –55 –35 –15 5 25 45 65 85 105 125 –55 –35 –15 5 25 45 65 85 105 125 –55 –35 –15 5 25 45 65 85 105 125 TEMPERATURE (°C) TEMPERATURE (°C) TEMPERATURE (°C) 6228 G04 6228 G05 6228 G06
Offset Voltage vs Input Common Mode Voltage Offset Voltage vs Output Current Warm Up Drift vs T W ime arm–up Drift vs T
100 200 50 V 90 S = ±5V VS = ±5V 180 VS = ±5V 80 TA=25°C V) 40 70 160 V) 60 T V) A = 125°C 140 50 TAGE (µ 30 40 T 120 A = 85°C TAGE (µ TAGE (µ 30 100 T 20 A = 125°C 20 80 10 10 OFFSET VOL 0 60 OFFSET VOL TA = 85°C –10 TA = –55°C 40 TA = –55°C –20 CHANGE IN OFFSET VOL 0 T –30 A = 25°C 20 TA = 25°C –40 0 –10 –6 –5 –4 –3 –2 –1 0 1 2 3 4 5 –50 –40 –30 –20 –10 0 10 20 30 40 50 0 1 2 3 4 5 6 7 8 INPUT COMMON MODE VOLTAGE (V) OUTPUT CURRENT (mA) TIME AFTER POWER UP (s) 6228 G07 6228 G08 6228 G09
Input Bias Current vs Input Input Bias Current vs Input Common Voltage, Bias Common Mode Voltage, Bias Cancellation Disabled Cancellation Enabled 0.1Hz to 10Hz Voltage Noise 0.1Hz to 10Hz V
5 2 VS = ±5V VS = ±5V 1 TA = 125°C 0 0 /Div) –1 –5 TA = –55°C –2 TA = 25°C –10 –3 T T A = –55°C A = 25°C –4 –15 T –5 A = 85°C TAGE NOISE (200 nV –6 –20 TA = 125°C INPUT BIAS CURRENT (µA) –7 INPUT BIAS CURRENT (µA) –25 TA = 85°C –8 INPUT VOL –9 –30 –10 –5.1 –4.2 –3.3 –2.4 –1.5 –0.7 0.2 1.1 2.0 2.9 3.8 –5.1 –4.2 –3.3 –2.4 –1.5 –0.7 0.2 1.1 2.0 2.9 3.8 1s/DIV 6228 G12 INPUT COMMON MODE VOLTAGE (V) INPUT COMMON MODE VOLTAGE (V) 6228 G10 6228 G11 Rev 0 10 For more information www.analog.com Document Outline Features Applications Typical Application Description Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics (VS = ±5V) Electrical Characteristics (VS = 5V, 0V) Electrical Characteristics (VS = 3V, 0V) Typical Performance Characteristics Pin Functions Applications Information Typical Applications Package Description Typical Application Related Parts
