21 /9 — MEAN: ±0.15mV. 300. 250. S IT N 200 U F O 150. MB U N 100. 0–0.6. –0.4. …
Revision
A
PDF / 1.5 Mb
MEAN: ±0.15mV. 300. 250. S IT N 200 U F O 150. MB U N 100. 0–0.6. –0.4. –0.2. 0.2. 0.4. 0.6. OS (mV). 180. AOL. 160. PHASE. 135. 140. ) s. 120. re g. 100. –20. –45
MEAN: ±0.15mV300250S IT N 200 U F O 150ERMB U N 100500–0.6–0.4–0.200.20.40.6 1 1 -3 V 7 OS (mV) 4 0 6 1 180180180AOL160160PHASE135140140) s120e120re g)eB10090)100B(D(dINR(d80RGOLRM80AC6045MA60SE40A40PH2002000 8 –20–45 0 9 0 0.010.11101001k10k100k1M10M -0 7 0.001 0.010.11101001k10k 100k1M10M 100M -0 4 7 0 4 FREQUENCY (Hz) 6 0 1 FREQUENCY (Hz) 6 1 15015010010050TA = –40°C50TA = 0°CTTA = –40°CA = +25°C)TA = 0°C(V)TA = +85°C(VTT0TA = +25°CU0UTOA = +85°COVV–50–50–100–100 0 1 1 –150 -0 1 7 4 –150 -0 0 7 4 TIME (1µs/DIV) 6 1 0 TIME (1µs/DIV) 6 1 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION TYPICAL APPLICATION CIRCUIT TABLE OF CONTENTS REVISION HISTORY FUNCTIONAL BLOCK DIAGRAM SPECIFICATIONS ±12 V TO ±110 V SUPPLY ABSOLUTE MAXIMUM RATINGS MAXIMUM POWER DISSIPATION THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION INTERNAL ELECTROSTATIC DISCHARGE (ESD) PROTECTION SLEW BOOST CIRCUIT AND PROTECTION DIGITAL GROUND (DGND) RESISTOR ADJUSTABLE QUIESCENT CURRENT (RADJ) SHUTDOWN PIN (SDB) TEMPERATURE MONITOR (TMP) OVERTEMPERATURE PROTECTION OUTPUT CURRENT DRIVE AND SHORT-CIRCUIT PROTECTION EXTERNAL COMPENSATION AND CAPACITIVE LOAD (CLOAD) DRIVING SAFE OPERATING AREA LFCSP PACKAGE AND HIGH VOLTAGE PIN SPACING EXPOSED PAD (EPAD) APPLICATIONS INFORMATION POWER SUPPLY AND DECOUPLING HIGH VOLTAGE GUARD RING HIGH VOLTAGE DAC VOLTAGE SUBTRACTOR HIGH CURRENT OUTPUT DRIVER SIGNAL RANGE EXTENDER OUTLINE DIMENSIONS ORDERING GUIDE
