Datasheet PZT2907A (ON Semiconductor) - 2
ManufacturerON Semiconductor
DescriptionPNP Bipolar Transistor
Pages / Page4 / 2 — PZT2907A. ELECTRICAL CHARACTERISTICS. Characteristic. Symbol. Min. Typ. …
Revision10
File Format / SizePDF / 105 Kb
PZT2907A. ELECTRICAL CHARACTERISTICS. Characteristic. Symbol. Min. Typ. Max. Unit. OFF CHARACTERISTICS. ON CHARACTERISTICS
PZT2907A ELECTRICAL CHARACTERISTICS Characteristic Symbol Min Typ Max Unit OFF CHARACTERISTICS ON CHARACTERISTICS
link to page 2
(TA = 25°C unless otherwise noted)
Collector−Base Breakdown Voltage V(BR)CBO Vdc (IC = −10 mAdc, IE = 0) −60 − − Collector−Emitter Breakdown Voltage V(BR)CEO Vdc (IC = 10 mAdc, IB = 0) −60 − − Emitter−Base Breakdown Voltage V(BR)EBO Vdc (IE = −10 mAdc, IC = 0) −5.0 − − Collector−Base Cutoff Current ICBO nAdc (VCB = −50 Vdc, IE = 0) − − −10 Collector−Emitter Cutoff Current ICEX nAdc (VCE = −30 Vdc, VBE = 0.5 Vdc) − − −50 Base−Emitter Cutoff Current IBEX nAdc (VCE = −30 Vdc, VBE = −0.5 Vdc) − − −50
ON CHARACTERISTICS
(Note 2) DC Current Gain hFE − (IC = −0.1 mAdc, VCE = −10 Vdc) 75 − − (IC = −1.0 mAdc, VCE = −10 Vdc) 100 − − (IC = −10 mAdc, VCE = −10 Vdc) 100 − − (IC = −150 mAdc, VCE = −10 Vdc) 100 − 300 (IC = −500 mAdc, VCE = −10 Vdc) 50 − − Collector-Emitter Saturation Voltages VCE(sat) Vdc (IC = −150 mAdc, IB = −15 mAdc) − − −0.4 (IC = − 500 mAdc, IB = −50 mAdc) − − −1.6 Base-Emitter Saturation Voltages VBE(sat) Vdc (IC = −150 mAdc, IB = −15 mAdc) − − −1.3 (IC = −500 mAdc, IB = −50 mAdc) − − −2.6
DYNAMIC CHARACTERISTICS
Current-Gain − Bandwidth Product fT MHz (IC = −50 mAdc, VCE = −20 Vdc, f = 100 MHz) 200 − − Output Capacitance Cc pF (VCB = −10 Vdc, IE = 0, f = 1.0 MHz) − − 8.0 Input Capacitance Ce pF (VEB = −2.0 Vdc, IC = 0, f = 1.0 MHz) − − 30
SWITCHING TIMES
Turn-On Time ton − − 45 ns (VCC = −30 Vdc, IC = −150 mAdc, Delay Time t I d − − 10 B1 = −15 mAdc) Rise Time tr − − 40 Turn-Off Time toff − − 100 ns (VCC = −6.0 Vdc, IC = −150 mAdc, Storage Time t I s − − 80 B1 = IB2 = −15 mAdc) Fall Time tf − − 30 2. Pulse Test: Pulse Width ≤ 300 ms, Duty Cycle ≤ 2.0%.
http://onsemi.com 2
