Datasheet RH1078M (Analog Devices) - 7
Description | Micropower, Dual, Single Supply Precision Op Amp |
Pages / Page | 8 / 7 — TYPICAL APPLICATIONS. Slew Rate. Gain-Bandwidth Product. 10Hz Noise … |
Revision | G |
File Format / Size | PDF / 161 Kb |
TYPICAL APPLICATIONS. Slew Rate. Gain-Bandwidth Product. 10Hz Noise Density. Output Voltage Swing Low,
RH1078M
TYPICAL APPLICATIONS Slew Rate Gain-Bandwidth Product 10Hz Noise Density
0.16 400 160 VS = ±15V VS = ±15V 0.14 350 140 ) Hz 0.12 300 120 VS = ±15V 0.10 250 100 0.08 VS = 5V, 0V 200 80 0.06 150 60 SLEW RATE (V/µs) 0.04 100 40 10Hz NOISE DENSITY (nV/√ 0.02 GAIN-BANDWIDTH PRODUCT (kHz) 50 20 0 0 0 1 10 100 1000 1 10 100 1000 1 10 100 1000 TOTAL DOSE-KRADs (Si) TOTAL DOSE-KRADs (Si) TOTAL DOSE-KRADs (Si) 1078M • G7 1078M • G8 1078M • G9
Output Voltage Swing Low, Positive Output Voltage Swing Negative Output Voltage Swing No Load
16 0 26 VS = ±15V RL = 50k VS = ±15V VS = 5V, 0V 14 –2 24 12 –4 20 RL = 2k 10 –6 18 8 –8 16 6 –10 12 4 –12 R 8 L = 2k OUTPUT VOLTAGE SWING (mV) 2 –14 4 POSITIVE OUTPUT VOLTAGE SWING (V) NEGATIVE OUTPUT VOLTAGE SWING (V) RL = 50k 0 –16 0 1 10 100 1000 1 10 100 1000 1 10 100 1000 TOTAL DOSE-KRADs (Si) TOTAL DOSE-KRADs (Si) TOTAL DOSE-KRADs (Si) 1078M • G10 1078M • G11 1078M • G12
Output Voltage Swing Low, Output Voltage Swing Low, 2k to GND ISINK = 100mA
1.6 160 VS = 5V, 0V VS = 5V, 0V 1.4 140 1.2 120 1.0 100 0.8 80 0.6 60 0.4 40 OUTPUT VOLTAGE SWING (mV) OUTPUT VOLTAGE SWING (mV) 0.2 20 0 0 1 10 100 1000 1 10 100 1000 TOTAL DOSE-KRADs (Si) TOTAL DOSE-KRADs (Si) 1078M • G13 1078M • G14 Rev. G For more information www.analog.com 7 Document Outline Description Package/Order Information Burn-In Circuit Total Dose Bias Circuit Absolute Maximum Ratings Table 1: Electrical Characteristics Table 1A: Electrical Characteristics Table 2: Electrical Test Requirements Typical Applications Revision History
