Datasheet RH118 (Analog Devices) - 4
DescriptionPrecision, High Speed Operational Amplifier
Pages / Page4 / 4 — TYPICAL PERFORMANCE CHARACTERISTICS. Input Offset Voltage. Input Bias …
RevisionC
File Format / SizePDF / 671 Kb
TYPICAL PERFORMANCE CHARACTERISTICS. Input Offset Voltage. Input Bias Current. Input Offset Current. Open-Loop Gain
TYPICAL PERFORMANCE CHARACTERISTICS Input Offset Voltage Input Bias Current Input Offset Current Open-Loop Gain
RH118
6 400 600 V V S = 20V S = 15V VS = 20V V V CM = 0V O = 10V V 4 500 CM = 0V RL = 2k 300 2 400 0 200 300 –2 200 OPEN-LOOP GAIN (V/mV) 100 INPUT BIAS CURRENT (nA) INPUT OFFSET VOLTAGE (mV) –4 100 –6 0 0 1 10 100 1000 1 10 100 1000 1 10 100 1000 TOTAL DOSE Krad (Si) TOTAL DOSE Krad (Si) TOTAL DOSE Krad (Si) RH118 G01 RH118 G02 RH118 G03
Open-Loop Gain Common Mode Rejection Ratio Power Supply Rejection Ratio
110 60 110 VS = 20V VS = 20V 100 VCM = 16.5V VCM = 0V 100 40 90 90 20 80 80 0 70 70 –20 60 60 INPUT OFFSET CURRENT (nA) –40 50 50 COMMON MODE REJECTION RATIO (dB) POWER SUPPLY REJECTION RATIO (dB) VS = 5V TO 20V 40 –60 40 1 10 100 1000 1 10 100 1000 1 10 100 1000 TOTAL DOSE Krad (Si) TOTAL DOSE Krad (Si) TOTAL DOSE Krad (Si) RH118 G04 RH118 G05 RH118 G06 I.D.No.66-11-0118 Rev. C 4 04/19 www.analog.com For more information www.analog.com ANALOG DEVICES, INC. 1989–2019 Document Outline Description Burn-In Circuit Package/Order Information Absolute Maximum Ratings Table 1: Electrical Characteristics Table 1A: Electrical Characteristics Electrical Characteristics Total Dose Bias Circuit Table 2: Electrical Test Requirements Revision History
