Datasheet AD7476-EP (Analog Devices) - 7
Description1MSPS, 12-Bit ADC in 6 Lead SOT-23
Pages / Page12 / 7 — AD7476-EP. PIN CONFIGURATION AND FUNCTION DESCRIPTIONS. GND 2. SDATA. TOP …
File Format / SizePDF / 182 Kb
AD7476-EP. PIN CONFIGURATION AND FUNCTION DESCRIPTIONS. GND 2. SDATA. TOP VIEW. VIN 3. (Not to Scale). SCLK
AD7476-EP PIN CONFIGURATION AND FUNCTION DESCRIPTIONS GND 2 SDATA TOP VIEW VIN 3 (Not to Scale) SCLK
AD7476-EP PIN CONFIGURATION AND FUNCTION DESCRIPTIONS V 1 DD 6 CS AD7476-EP GND 2 5 SDATA
3
TOP VIEW
00
VIN 3 (Not to Scale) 4 SCLK
24- 092 Figure 3. Pin Configuration
Table 4. Pin Function Descriptions Pin No. Mnemonic Description
1 VDD Power Supply Input. The VDD range for the AD7476-EP is from 2.35 V to 5.25 V. 2 GND Analog Ground. Ground reference point for all circuitry on the part. All analog input signals should be referred to this GND voltage. 3 VIN Analog Input. Single-ended analog input channel. The input range is 0 V to VDD. 4 SCLK Serial Clock. Logic input. SCLK provides the serial clock for accessing data from the part. This clock input is also used as the clock source for the AD7476-EP conversion process. 5 SDATA Data Out. Logic output. The conversion result is provided on this output as a serial data stream. The bits are clocked out on the falling edge of the SCLK input. The data stream from the AD7476-EP consists of four leading zeros followed by the 12 bits of conversion data; this is provided MSB first. 6 CS Chip Select. Active low logic input. This input provides the dual function of initiating conversions on the AD7476-EP and framing the serial data transfer. Rev. 0 | Page 7 of 12 Document Outline FEATURES ENHANCED PRODUCT FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM PRODUCT HIGHLIGHTS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS TIMING SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS OUTLINE DIMENSIONS ORDERING GUIDE
