Datasheet AD8285 (Analog Devices) - 10
DescriptionRadar Receive Path AFE: 4-Channel LNA/PGA/AAF with ADC
Pages / Page27 / 10 — AD8285. Data Sheet. TYPICAL PERFORMANCE CHARACTERISTICS. 40 38. 34dB. …
RevisionB
File Format / SizePDF / 511 Kb
AD8285. Data Sheet. TYPICAL PERFORMANCE CHARACTERISTICS. 40 38. 34dB. 28dB. 22dB. ES (%. 16dB. EVI. D F. G L. E O G. NNE. –10. CHA. E C. 12 10. –20. PER. 8 6
AD8285 Data Sheet TYPICAL PERFORMANCE CHARACTERISTICS 40 38 34dB 28dB 22dB ES (% 16dB EVI D F G L E O G NNE –10 CHA E C 12 10 –20 PER 8 6
AVDD18 = AVDD18ADC = 1.8 V, AVDD33A = AVDD33B = AVDD33C = AVDD33D = AVDD33 = AVDD33REF = AVDD33CLK = 3.3 V, TA = 25°C, fS = 72 MSPS, RIN = 200 kΩ, VREF = 1.024 V.
50 40 38 40 36 34dB 34 ) 32 30 28dB 30 22dB B) ES (% 28 20 C (d 16dB 26 N EVI 24 AI 10 D F 22 G L 20 0 E O G 18 NNE 16 TA –10 N 14 CHA E C 12 10 –20 PER 8 6 –30 4 2 –40 0 0.1 1 10 100 33.50 33.66 33.82 33.98 34.14 34.30 34.46
33 -014 0
33.58 33.74 33.90 34.06 34.22 34.38
52-
FREQUENCY (MHz)
952 1
GAIN ERROR (dB)
19 1 1 Figure 4. Channel Gain vs. Frequency Figure 7. Gain Error Histogram (Gain = 34 dB)
1.0 20 34dB 19 28dB 0.8 18 22dB 16dB 17 ) 0.6 16 (% 15 0.4 ES 14 B) C 13 d 0.2 EVI 12 R ( D F 11 0 10 RRO O E 9 G N E –0.2 A 8 AI T 7 G –0.4 EN C 6 R 5 E –0.6 P 4 3 –0.8 2 1 –1.0 0 –40 –15 10 35 60 85
38
0 0.02 0.04 0.06 0.08 0.10 0.12 0.14 0.16 0.18 0.20 0.22 0.24
34 0 0 2-
0.01 0.03 0.05 0.07 0.09 0.11 0.13 0.15 0.17 0.19 0.21 0.23 0.25
52-
TEMPERATURE (°C)
95 1
GAIN MATCHING (dB)
1 119 Figure 5. Gain Error vs. Temperature at All Gains Figure 8. Channel-to-Channel Gain Matching (Gain = 16 dB)
40 10 38 36 9 34 ) ) % 32 8 ( 30 S 28 ES (% 7 ICE C V 26 24 EVI 6 DE F 22 D F O 20 O 5 E 18 E G AG 16 4 TA NT 14 N E CE 12 C 3 R 10 E P 8 PER 2 6 4 1 2 0
2
0 16.00 16.16 16.32 16.48 16.64 16.8 16.96
5 03
0 0.02 0.04 0.06 0.08 0.10 0.12 0.14 0.16 0.18 0.20 0.22 0.24 16.08 16.24 16.4 16.56 16.72 16.88
2- 03
2-
GAIN ERROR (dB)
95 11
GAIN MATCHING (dB)
195 1 Figure 6. Gain Error Histogram (Gain = 16 dB) Figure 9. Channel-to-Channel Gain Matching (Gain = 34 dB) Rev. B | Page 10 of 27 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS AC SPECIFICATIONS DIGITAL SPECIFICATIONS SWITCHING SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION RADAR RECEIVE PATH AFE CHANNEL OVERVIEW Low Noise Amplifier (LNA) Recommendation Antialiasing Filter (AAF) Mux and Mux Controller ADC CLOCK INPUT CONSIDERATIONS CLOCK DUTY CYCLE CONSIDERATIONS CLOCK JITTER CONSIDERATIONS SDIO PIN SCLK PIN CS\ PIN RBIAS PIN VOLTAGE REFERENCE POWER AND GROUND RECOMMENDATIONS EXPOSED PADDLE THERMAL HEAT SLUG RECOMMENDATIONS SERIAL PERIPHERAL INTERFACE (SPI) HARDWARE INTERFACE MEMORY MAP READING THE MEMORY MAP TABLE LOGIC LEVELS RESERVED LOCATIONS DEFAULT VALUES APPLICATION DIAGRAMS OUTLINE DIMENSIONS ORDERING GUIDE AUTOMOTIVE PRODUCTS
