Datasheet LTM9011-14, LTM9010-14, LTM9009-14 (Analog Devices) - 2
Description14-Bit, 125Msps Low Power Octal ADCs
Pages / Page40 / 2 — (Notes 1, 2). http://www.linear.com/product/LTM9011-14#orderinfo. LEAD …
RevisionD
(Notes 1, 2). http://www.linear.com/product/LTM9011-14#orderinfo. LEAD FREE FINISH. TRAY. PART MARKING*. PACKAGE DESCRIPTION
(Notes 1, 2) http://www.linear.com/product/LTM9011-14#orderinfo LEAD FREE FINISH TRAY PART MARKING* PACKAGE DESCRIPTION
LTM9011-14/ LTM9010-14/LTM9009-14 ABSOLUTE MAXIMUM RATINGS PIN CONFIGURATION
(Notes 1, 2)
Supply Voltages TOP VIEW VDD, OVDD .. –0.3V to 2V A Analog Input Voltage (A + – IN , AIN , B PAR/SER, SENSE) (Note 3) .. –0.3V to (VDD + 0.2V) C Digital Input Voltage (ENC+, ENC–, CS, D SDI, SCK) (Note 4) .. –0.3V to 3.9V E SDO (Note 4) ... –0.3V to 3.9V F Digital Output Voltage .. –0.3V to (OVDD + 0.3V) G Operating Temperature Range H LTM9011C, LTM9010C, LTM9009C ... 0°C to 70°C J LTM9011I, LTM9010I, LTM9009I ...–40°C to 85°C K Storage Temperature Range .. –55°C to 125°C L M N P 1 2 3 4 5 6 7 8 9 10 BGA PACKAGE 140-LEAD (11.25mm × 9.00mm × 2.72mm) TJMAX = 150°C, θJA = 30°C/W, θJC = 25°C/W, θJB = 15°C/W, θJCbottom = 12°C/W ORDER INFORMATION
http://www.linear.com/product/LTM9011-14#orderinfo LEAD FREE FINISH TRAY PART MARKING* PACKAGE DESCRIPTION TEMPERATURE RANGE
LTM9011CY-14#PBF LTM9011CY-14#PBF LTM9011Y14 140-Lead (11.25mm × 9mm × 2.72mm) BGA 0°C to 70°C LTM9011IY-14#PBF LTM9011IY-14#PBF LTM9011Y14 140-Lead (11.25mm × 9mm × 2.72mm) BGA –40°C to 85°C LTM9010CY-14#PBF LTM9010CY-14#PBF LTM9010Y14 140-Lead (11.25mm × 9mm × 2.72mm) BGA 0°C to 70°C LTM9010IY-14#PBF LTM9010IY-14#PBF LTM9010Y14 140-Lead (11.25mm × 9mm × 2.72mm) BGA –40°C to 85°C LTM9009CY-14#PBF LTM9009CY-14#PBF LTM9009Y14 140-Lead (11.25mm × 9mm × 2.72mm) BGA 0°C to 70°C LTM9009IY-14#PBF LTM9009IY-14#PBF LTM9009Y14 140-Lead (11.25mm × 9mm × 2.72mm) BGA –40°C to 85°C Consult LTC Marketing for parts specified with wider operating temperature ranges. *The temperature grade is identified by a label on the shipping container. For more information on lead free part marking, go to: http://www.linear.com/leadfree/ For more information on tape and reel specifications, go to: http://www.linear.com/tapeandreel/. Some packages are available in 500 unit reels through designated sales channels with #TRMPBF suffix. Rev D 2 For more information www.analog.com Document Outline Features Applications Description Typical Application Absolute Maximum Ratings Pin Configuration Order Information Converter Characteristics Analog Input Dynamic Accuracy Internal Reference Characteristics Digital Inputs And Outputs Power Requirements Timing Characteristics Timing Diagrams Typical Performance Characteristics Pin Functions Pin Configuration Table Functional Block Diagram Applications Information Typical Applications Package Description Revision History Typical Application Related Parts
