Datasheet LT6658 (Analog Devices) - 9
Description | Precision Dual Output, High Current, Low Noise, Voltage Reference |
Pages / Page | 44 / 9 — TYPICAL PERFORMANCE CHARACTERISTICS TA = 25°C, VIN = VIN1 = VIN2 = … |
Revision | C |
File Format / Size | PDF / 4.2 Mb |
TYPICAL PERFORMANCE CHARACTERISTICS TA = 25°C, VIN = VIN1 = VIN2 = VOUT1_F + 2.5V =
LT6658
TYPICAL PERFORMANCE CHARACTERISTICS TA = 25°C, VIN = VIN1 = VIN2 = VOUT1_F + 2.5V = VOUT2_F + 2.5V except LT6658-1.2 where VIN = VIN1 = VIN2 = 4.5V, COUT1 = COUT2 = 1µF, ILOAD = 0mA, unless otherwise noted. The characteristic curves are similar across the LT6658 family. Curves from the LT6658-1.2, LT6658-2.5 and the LT6658-5 represent the full range of typical performance of all voltage options. Characteristic curves for other output voltages fall between these curves and can be estimated based on their output. 1.2V Supply Current vs 1.2V VOUT1 Power Supply 1.2V VOUT2 Power Supply Input Voltage Rejection Ratio vs Frequency Rejection Ratio vs Frequency
2.5 120 120 VIN = VIN1 = VIN2 = 5V VIN = VIN1 = VIN2 = 5V COUT1 = 1µF COUT2 = 1µF 100 ILOAD = 0A 100 ILOAD = 0A 2.0 80 80 1.5 60 60 1.0 PSRR (dB) PSRR (dB) 40 40 INPUT CURRENT (mA) 0.5 125°C 20 25°C C 20 NR = 1µF C –45°C C NR = 1µF NR = 10µF C 0 0 NR = 10µF 0 4 8 12 16 20 24 28 32 36 40 0.01 0.1 1 10 100 1000 00.01 0.1 1 10 100 1000 INPUT VOLTAGE (V) FREQUENCY (kHz) FREQUENCY (kHz) 6658 G10 6658 G11 6658 G12
1.2V VOUT1 Power Supply 1.2V VOUT2 Power Supply 1.2V VOUT1 AC Output Impedance Rejection Ratio vs Frequency Rejection Ratio vs Frequency 10mA Load
120 120 1 VIN = VIN1 = VIN2 = 5V VIN = VIN1 = VIN2 = 5V IOUT1 = 10mA CNR = 10µF CNR = 10µF 100 COUT1 = 1µF 100 COUT2 = 1µF 0.1 80 80 60 60 0.01 PSRR (dB) PSRR (dB) 40 40 OUTPUT IMPEDANCE (Ω) 0.001 20 20 ILOAD1 = 0mA I C LOAD = 0mA OUT1 = 1µF ILOAD1 = 150mA I C LOAD = 50mA OUT1 = 50µF 0 0 0.0001 0.01 0.1 1 10 100 1000 0.01 0.1 1 10 100 1000 0.01 0.1 1 10 100 1000 FREQUENCY (kHz) FREQUENCY (kHz) FREQUENCY (kHz) 6658 G13 6658 G14 6658 G15
1.2V VOUT1 AC Output Impedance 1.2V VOUT2 AC Output Impedance 1.2V VOUT2 AC Output Impedance 150mA Load 1mA Load 50mA Load
1 1 1 IOUT1 = 150mA IOUT1 = 1mA IOUT1 = 50mA 0.1 0.1 0.1 0.01 0.01 0.01 OUTPUT IMPEDANCE (Ω) 0.001 OUTPUT IMPEDANCE (Ω) 0.001 OUTPUT IMPEDANCE (Ω) 0.001 COUT1 = 1µF COUT2 = 1µF COUT2 = 1µF COUT1 = 50µF COUT2 = 50µF COUT2 = 50µF 0.0001 0.0001 0.0001 0.01 0.1 1 10 100 1000 0.01 0.1 1 10 100 1000 0.01 0.1 1 10 100 1000 FREQUENCY (kHz) FREQUENCY (kHz) FREQUENCY (kHz) 6658 G16 6658 G17 6658 G18 Rev. C For more information www.analog.com 9 Document Outline Features Applications Typical Application Description Absolute Maximum Ratings Pin Configuration Order Information Available Options Electrical Characteristics Typical Performance Characteristics Pin Functions Block Diagram Applications Information Typical Applications Package Description Revision History Typical Application Related Parts
