Datasheet LT6658 (Analog Devices) - 10
Description | Precision Dual Output, High Current, Low Noise, Voltage Reference |
Pages / Page | 44 / 10 — TYPICAL PERFORMANCE CHARACTERISTICS TA = 25°C, VIN = VIN1 = VIN2 = … |
Revision | C |
File Format / Size | PDF / 4.2 Mb |
TYPICAL PERFORMANCE CHARACTERISTICS TA = 25°C, VIN = VIN1 = VIN2 = VOUT1_F + 2.5V =
LT6658
TYPICAL PERFORMANCE CHARACTERISTICS TA = 25°C, VIN = VIN1 = VIN2 = VOUT1_F + 2.5V = VOUT2_F + 2.5V except LT6658-1.2 where VIN = VIN1 = VIN2 = 4.5V, COUT1 = COUT2 = 1µF, ILOAD = 0mA, unless otherwise noted. The characteristic curves are similar across the LT6658 family. Curves from the LT6658-1.2, LT6658-2.5 and the LT6658-5 represent the full range of typical performance of all voltage options. Characteristic curves for other output voltages fall between these curves and can be estimated based on their output. 1.2V Channel to Channel Load 1.2V Channel to Channel Load 1.2V Turn-On Characteristic Isolation VOUT2 to VOUT1 Isolation VOUT1 to VOUT2
V 50mV 50mV 5V/DIV IN 140 RMS SIGNAL ON VOUT2 140 RMS SIGNAL ON VOUT1 VBYPASS TION (dB) 120 TION (dB) 120 2V/DIV 100 100 VOUT1 2V/DIV 80 80 VOUT2 2V/DIV C 60 60 NR = OPEN COUT1 = 1µF COUT2 = 1µF 40 40 50µs/DIV 6658 G19 CHANNEL TO CHANNEL ISOLA 20 I CHANNEL TO CHANNEL ISOLA LOAD2 = 50mA 20 ILOAD1 = 150mA I I V OUT1 LOAD2 = 0mA LOAD1 = 0mA 0 V OUT2 0 0.001 0.1 1 10 100 1000 0.001 0.1 1 10 100 1000 FREQUENCY (kHz) FREQUENCY (kHz) 6658 G20 6658 G21
1.2V VOUT1 Output Noise 1.2V VOUT2 Output Noise 1.2V VOUT1 Output Voltage Noise 0.1Hz to 10Hz 0.1Hz to 10Hz Spectrum ILOAD = 0mA
250 COUT1 = 1µF 200 ) Hz /√ 1µV/DIV 1µV/DIV 150 TAGE (nV 100 CNR = OPEN NOISE VOL 50 1s/DIV 6658 G22 1s/DIV 6658 G23 CNR = 10µF 00.01 0.1 1 10 100 1000 FREQUENCY (kHz) 6658 G24
1.2V VOUT2 Output Voltage Noise Spectrum ILOAD = 0mA 1.2V Line Transient Response 1.2V Line Transient Response
250 COUT2 = 1µF 500mV/DIV VIN 500mV/DIV VIN 200 VBYPASS VBYPASS ) 2mV/DIV 2mV/DIV Hz /√ VOUT1 VOUT1 150 2mV/DIV 2mV/DIV VOUT2 VOUT2 TAGE (nV 2mV/DIV 2mV/DIV 100 CNR = OPEN CNR = OPEN VIN = 4.5V TO 5V CNR = 1µF VIN = 4.5V to 5V COUT1 = COUT2 = 1µF ILOAD = 0mA C NOISE VOL OUT1 = COUT2 = 1µF ILOAD = 0mA 50 50µs/DIV 6658 G26 50µs/DIV 6658 G27 CNR = 10µF 00.01 0.1 1 10 100 1000 FREQUENCY (kHz) 6658 G25 Rev. C 10 For more information www.analog.com Document Outline Features Applications Typical Application Description Absolute Maximum Ratings Pin Configuration Order Information Available Options Electrical Characteristics Typical Performance Characteristics Pin Functions Block Diagram Applications Information Typical Applications Package Description Revision History Typical Application Related Parts
