Datasheet RH1021-10 (Analog Devices) - 2
DescriptionPrecision 10V Reference
Pages / Page6 / 2 — ORDER INFORMATION LEAD BASED FINISH. TAPE AND REEL. PART MARKING. PACKAGE …
RevisionF
File Format / SizePDF / 667 Kb
ORDER INFORMATION LEAD BASED FINISH. TAPE AND REEL. PART MARKING. PACKAGE DESCRIPTION. TEMPERATURE RANGE
ORDER INFORMATION LEAD BASED FINISH TAPE AND REEL PART MARKING PACKAGE DESCRIPTION TEMPERATURE RANGE
RH1021-10
RH1021BMH-10 RH1021BMH-10#TR 8-Lead TO-5 Metal Can –55°C to 125°C RH1021CMH-10 RH1021CMH-10#TR 8-Lead TO-5 Metal Can –55°C to 125°C RH1021DMH-10 RH1021DMH-10#TR 8-Lead TO-5 Metal Can –55°C to 125°C RH1021CMW-10 RH1021CMW-10#TR 10-Lead CERPAC –55°C to 125°C Contact the factory for parts specified with wider operating temperature ranges. Tape and reel specifications.
TABLE 1: ELECTRICAL CHARACTERISTICS (Preirradiation) (Note 9) TA = 25°C SUB- –55°C ≤ TA ≤ 125°C SUB- SYMBOL PARAMETER CONDITIONS NOTES MIN TYP MAX GROUP MIN TYP MAX GROUP UNITS
VOUT Output Voltage RH1021CM-10 1 9.995 10.005 1 V RH1021BM-10, DM-10 1 9.95 10.05 1 V TCVOUT Output Voltage RH1021BM-10 2 5 2, 3 ppm/°C Temperature Coefficient RH1021CM-10, DM-10 2 20 2, 3 ppm/°C ∆VOUT Line Regulation 11.5V ≤ VIN ≤ 14.5V 3 4 1 6 2, 3 ppm/V ∆VIN 14.5V ≤ VIN ≤ 40V 3 2 1 4 2, 3 ppm/V ∆VOUT Load Regulation 0 ≤ IOUT ≤ 10mA 3 25 1 40 2, 3 ppm/mA ∆IOUT (Sourcing Current) Load Regulation (Shunt Mode) 1.7mA ≤ IOUT ≤ 10mA 3, 4 100 1 150 2, 3 ppm/mA IS Supply Current (Series Mode) 1.7 1 2.0 2, 3 mA IMIN Minimum Current (Shunt Mode) VIN is Open 1.5 1 1.7 2, 3 mA Output Voltage Noise 0.1Hz ≤ f ≤ 10Hz 5 6 µVP-P 10Hz ≤ f ≤ 1kHz 5 6 4 µVRMS Long-Term Stability of VOUT ∆T = 1000 Hrs 6 15 ppm Noncumulative Temperature Hysteresis of VOUT ∆T = ±25°C 5 ppm Rev F 2 Document Outline Description Absolute Maximum Ratings Burn-In Circuits Pin Configuration Order Information Table 1: Electrical Characteristics Table 1A: Electrical Characteristics Table 2: Electrical Test Requirements Total Dose Bias Circuit Revision History Typical Performance Characteristics
