Datasheet HMC997LC4 (Analog Devices)
DescriptionAnalog Variable Gain Amplifier SMT, 17 - 27 GHz
Pages / Page8 / 1 — HMC997LC4. VARIABLE GAIN AMPLIFIER. 17 - 27 GHz. Typical Applications. …
File Format / SizePDF / 465 Kb
HMC997LC4. VARIABLE GAIN AMPLIFIER. 17 - 27 GHz. Typical Applications. Features. Functional Diagram. General Description
Datasheet HMC997LC4 Analog Devices
HMC997LC4
v02.0514
VARIABLE GAIN AMPLIFIER 17 - 27 GHz Typical Applications Features
The HmC997lC4 is ideal for: Wide Gain Control range: 15 db T • point-to-point radio Single Control Voltage m • point-to-multi-point radio Output ip3 @ max Gain: +31 dbm • eW & eCm Subsystems Output p1db: +24 dbm r - S • Ka-band radar no external matching ie 24 lead 4 x 4 mm SmT package: 16 mm2 • Test equipment lif
p The HmC997lC4 is a Gaas mmiC pHemT analog m variable gain amplifier and/or driver amplifier which a operates between 17 and 27 GHz. ideal for microwave in radio applications, the amplifier provides up to 20.5 a db of gain, output p1db of up to +24 dbm, and up to +31 dbm of output ip3 at maximum gain, while requiring only 170 ma from a +5V supply. a gain control voltage (Vctrl) is provided to al ow variable le G b gain control up to 15 db. Gain flatness is excel ent making the HmC997lC4 ideal for eW, eCm and radar ia applications. The HmC997lC4 is housed in a roHS r compliant 4 x 4 mm ceramic Qfn leadless package a V and is compatible with high volume surface mount manufacturing.
Electrical Specifications, T = +25 °C, Vdd1, 2, 3 = 5V, Vctrl = -4.5V, Idd = 170 mA* A
parameter min. Typ. max. min. Typ. max. Units frequency range 17 - 21 21 - 27 GHz Gain 17.0 20 16 19 db Gain flatness ±0.3 ±0.7 db Gain Variation Over Temperature 0.02 0.02 db/ °C Gain Control range 12 15 12 14 db noise figure 4.0 3.5 db input return loss 13 12 db Output return loss 17 19 db Output power for 1 db Compression (p1db) 21 24 21 24 dbm Saturated Output power (psat) 25 24.5 dbm Output Third Order intercept (ip3) 31 30 dbm Total Supply Current (idd) 170 170 ma *Set Vctrl = -4.5V and then adjust Vgg1, 2 between -2V to 0V to achieve idd = 170 ma typical. Inf F or o m r p atio r n ifc ur e n , d ishe e d lbiv y e A r n y a alog n D d t evic o p es is la beclie o eved rd to ebre sa: H ccur iattti e tae M nd re ilicarbloew . H a o ve C wever, o n rp o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other oration, 2 Elizabeth Drive, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 O rights of third parties that may result from its use. Specifications subject to change without notice. No P rd hone e r O : 7 n 81- -3li 2n 9 e a -47 t w 0 w 0 • O w rd .h e it r o t niltie n .c e ao t m
1
license is granted by implication or otherwise under any patent or patent rights of Analog Devices. www.analog.com Application Support: Pho Trademarks and registered trademarks are the property of their respective owners. ne: 978-250-33 A 4 pp3li o ca rti a o pp n Susp@h portitti : P te ho .c neom : 1-800-ANALOG-D
