Datasheet HMC997LC4 (Analog Devices) - 4
DescriptionAnalog Variable Gain Amplifier SMT, 17 - 27 GHz
Pages / Page8 / 4 — HMC997LC4. VARIABLE GAIN AMPLIFIER. 17 - 27 GHz. Reverse Isolation vs. …
File Format / SizePDF / 465 Kb
HMC997LC4. VARIABLE GAIN AMPLIFIER. 17 - 27 GHz. Reverse Isolation vs. Temperature. Output IP3 vs. Temperature
HMC997LC4 VARIABLE GAIN AMPLIFIER 17 - 27 GHz Reverse Isolation vs Temperature Output IP3 vs Temperature
HMC997LC4
v02.0514
VARIABLE GAIN AMPLIFIER 17 - 27 GHz Reverse Isolation vs. Temperature Output IP3 vs. Temperature
0 40 -10 +25C +25C +85C 35 +85C -40C Vctrl=-4.5V, Pout=+14dBm -40C T -20 ) 30 m -30 (dB ) N IO -40 T (dBm 25 LA IP3 O -50 IS 20 r - S Vctrl=-1V, Pout=+14dBm -60 ie 15 -70 -80 10 lif 16 18 20 22 24 26 28 17 18 19 20 21 22 23 24 25 26 27 p FREQUENCY (GHz) FREQUENCY (GHz) m a in
IP3 and Gain @ 18 GHz Pin = -20 dBm IP3 and Gain @ 22 GHz Pin = -20 dBm
a 40 40 35 35 30 30 (dB) le G (dB) 25 25 b GAIN GAIN ), 20 ), 20 ia (dBm 15 (dBm 15 r IP3 10 IP3 10 a OIP3 OIP3 V 5 GAIN 5 GAIN IIP3 IIP3 0 0 -4.5 -4 -3.5 -3 -2.5 -2 -1.5 -1 -4.5 -4 -3.5 -3 -2.5 -2 -1.5 -1 CONTROL VOLTAGE (V) CONTROL VOLTAGE (V)
IP3 and Gain @ 26 GHz Pin = -20 dBm
40 35 OIP3 GAIN 30 IIP3 (dB) 25 GAIN ), 20 (dBm 15 IP3 10 5 0 -4.5 -4 -3.5 -3 -2.5 -2 -1.5 -1 CONTROL VOLTAGE (V) Inf F or o m r p atio r n ifc ur e n , d ishe e d lbiv y e A r n y a alog n D d t evic o p es is la beclie o eved rd to ebre sa: H ccur iattti e tae M nd re ilicarbloew . H a o ve C wever, o n rp o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other oration, 2 Elizabeth Drive, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 O rights of third parties that may result from its use. Specifications subject to change without notice. No P rd hone e r O : 7 n 81- -3li 2n 9 e a -47 t w 0 w 0 • O w rd .h e it r o t niltie n .c e ao t m license is granted by implication or otherwise under any patent or patent rights of Analog Devices. www.analog.com
4
Application Support: Pho Trademarks and registered trademarks are the property of their respective owners. ne: 978-250-33 A 4 pp3li o ca rti a o pp n Susp@h portitti : P te ho .c neom : 1-800-ANALOG-D
