Datasheet HMC996LP4E (Analog Devices) - 4
DescriptionAnalog Variable Gain Amplifier SMT, 5 - 12 GHz
Pages / Page8 / 4 — HMC996LP4E. VARIABLE GAIN AMPLIFIER. 5 - 12 GHz. Reverse Isolation vs. …
File Format / SizePDF / 491 Kb
HMC996LP4E. VARIABLE GAIN AMPLIFIER. 5 - 12 GHz. Reverse Isolation vs. Temperature. Output IP3 vs. Temperature
HMC996LP4E VARIABLE GAIN AMPLIFIER 5 - 12 GHz Reverse Isolation vs Temperature Output IP3 vs Temperature
HMC996LP4E
v01.0112
VARIABLE GAIN AMPLIFIER 5 - 12 GHz Reverse Isolation vs. Temperature Output IP3 vs. Temperature
0 40 Vctrl=-4.5V, Pout=7 dBm/tone -10 +25C +85C 35 T -20 -40C ) 30 m -30 (dB ) N +25C IO -40 T (dBm 25 +85C -40C LA IP3 O -50 IS 20 r - S -60 ie 15 -70 Vctrl=-1V, Pout=-14 dBm/tone -80 10 lif 5 6 7 8 9 10 11 12 5 6 7 8 9 10 11 12 p FREQUENCY (GHz) FREQUENCY (GHz) m a in
IP3 and Gain @ 6 GHz, Pin = -10 dBm IP3 and Gain @ 8 GHz, Pin = -10 dBm
a 40 40 35 OIP3 35 OIP3 GAIN GAIN 30 IIP3 30 IIP3 le G (dB) 25 (dB) 25 b GAIN 20 20 GAIN ), ), 15 15 ia (dBm (dBm 10 10 r IP3 IP3 a 5 5 V 0 0 -5 -5 -4.5 -4 -3.5 -3 -2.5 -2 -1.5 -1 -4.5 -4 -3.5 -3 -2.5 -2 -1.5 -1 CONTROL VOLTAGE (V) CONTROL VOLTAGE (V)
IP3 and Gain @ 10 GHz, Pin = -10 dBm
40 35 OIP3 GAIN 30 IIP3 (dB) 25 GAIN 20 ), 15 (dBm 10 IP3 5 0 -5 -4.5 -4 -3.5 -3 -2.5 -2 -1.5 -1 CONTROL VOLTAGE (V) Inf F or o m r p atio r n ifc ur e n , d ishe e d lbiv y e A r n y a alog n D d t evic o p es is la beclie o eved rd to ebre sa: H ccur iattti e tae M nd re ilicarbloew . H a o ve C wever, o n rp o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other oration, 2 Elizabeth Drive, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 O rights of third parties that may result from its use. Specifications subject to change without notice. No P rd ho e ne r O : 7 n 81- -3li 2n 9 e a -47 t w 0 w 0 • O w rd .h e it r o tniltie n .c e ao t m license is granted by implication or otherwise under any patent or patent rights of Analog Devices. www.analog.com
4
Application Support: Pho Trademarks and registered trademarks are the property of their respective owners. ne: 978-250-33 A 4 p 3 o plica r a tio p n S p u s p @ po h rt itt : P ite ho . n c e o : 1m -800-ANALOG-D
