Datasheet HMC996LP4E (Analog Devices) - 5
DescriptionAnalog Variable Gain Amplifier SMT, 5 - 12 GHz
Pages / Page8 / 5 — HMC996LP4E. VARIABLE GAIN AMPLIFIER. 5 - 12 GHz. Absolute Maximum …
File Format / SizePDF / 491 Kb
HMC996LP4E. VARIABLE GAIN AMPLIFIER. 5 - 12 GHz. Absolute Maximum Ratings. Bias Voltage. Outline Drawing. Package Information
HMC996LP4E VARIABLE GAIN AMPLIFIER 5 - 12 GHz Absolute Maximum Ratings Bias Voltage Outline Drawing Package Information
HMC996LP4E
v01.0112
Drain bias Voltage (Vdd1, 2) +5.5V Vdd1,2(V) idd Total (ma) T Gate bias Voltage (Vgg1, 2) -3 to 0V +5V 120 ma m Gain Control Voltage (Vctrl) -5 to 0V Vgg1,2 (V) igg Total (ma) rf power input +20 dbm 0V to -2V <0.1 ma Channel Temperature 175 °C r - S Continuous pdiss (T = 85 °C) 1.03 W (derate 11.5 mW/°C above 85 °C) [1] ie eleCTrOSTaTiC SenSiTiVe DeViCe Thermal resistance 86.7 °C/W (Channel to ground paddle) ObSerVe HanDlinG preCaUTiOnS lif Storage Temperature -65 to +150 °C p Operating Temperature -40 to +85 °C m eSD Sensitivity (Hbm) Class 0 passed 150V a in a
Outline Drawing
le G b ia r a V nOTeS: 1. leaDframe maTerial: COpper allOY 2. DimenSiOnS are in inCHeS [millimeTerS] 3. leaD SpaCinG TOleranCe iS nOn-CUmUlaTiVe. 4. PAD BURR LENGTH SHALL BE 0.15mm MAXIMUM. PAD BURR HEIGHT SHALL BE 0.05mm MAXIMUM. 5. PACKAGE WARP SHALL NOT EXCEED 0.05mm. 6. all GrOUnD leaDS anD GrOUnD paDDle mUST be SOlDereD TO pCb rf GrOUnD. 7. refer TO HiTTiTe appliCaTiOn nOTe fOr SUGGeSTeD lanD paTTern.
Package Information
part number package body material lead finish mSl rating package marking [2] HmC996lp4e roHS-compliant low Stress injection molded plastic 100% matte Sn mSl1 [1] H996 XXXX [1] max peak reflow temperature of 260 °C [2] 4-Digit lot number XXXX Inf F or o m r p atio r n ifc ur e n , d ishe e d lbiv y e A r n y a alog n D d t evic o p es is la beclie o eved rd to ebre sa: H ccur iattti e tae M nd re ilicarbloew . H a o ve C wever, o n rp o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other oration, 2 Elizabeth Drive, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 O rights of third parties that may result from its use. Specifications subject to change without notice. No P rd ho e ne r O : 7 n 81- -3li 2n 9 e a -47 t w 0 w 0 • O w rd .h e it r o tniltie n .c e ao t m
5
license is granted by implication or otherwise under any patent or patent rights of Analog Devices. www.analog.com Application Support: Pho Trademarks and registered trademarks are the property of their respective owners. ne: 978-250-33 A 4 p 3 o plica r a tio p n S p u s p @ po h rt itt : P ite ho . n c e o : 1m -800-ANALOG-D
