Datasheet HMC694 (Analog Devices) - 4
DescriptionAnalog Variable Gain Amplifier Chip, 6 - 17 GHz
Pages / Page8 / 4 — HMC694. GaAs MMIC ANALOG VARIABLE. GAIN AMPLIFIER, 6 - 17 GHz. Reverse …
File Format / SizePDF / 478 Kb
HMC694. GaAs MMIC ANALOG VARIABLE. GAIN AMPLIFIER, 6 - 17 GHz. Reverse Isolation vs. Temperature. Output IP3 vs. Temperature
HMC694 GaAs MMIC ANALOG VARIABLE GAIN AMPLIFIER, 6 - 17 GHz Reverse Isolation vs Temperature Output IP3 vs Temperature
HMC694
v03.1108
GaAs MMIC ANALOG VARIABLE GAIN AMPLIFIER, 6 - 17 GHz Reverse Isolation vs. Temperature Output IP3 vs. Temperature
0 34 ) -10 30 (dB N +25C -20 IO +85C 26 T -55C Vctrl = -2V, Pout = 15dBm LA O -30 22 (dBm) IS Vctrl = 0V, Pout = 8dBm E S IP3 R -40 18 E V E R -50 14 +25C +85C -55C -60 10 6 8 10 12 14 16 18 4 6 8 10 12 14 16 18 FREQUENCY (GHz) FREQUENCY (GHz) 6
Output IP3 @ 0 dBm Output IP3 @ 5 dBm
28 28 ip 26 26 H 16 GHz 24 24 12 GHz ) 22 ) 22 s - C (dBm 20 (dBm 20 7 GHz IP3 IP3 r 18 18 7 GHz 12 GHz ie 16 16 16 GHz 14 14 lif 12 12 p -0.8 -0.6 -0.4 -0.2 0 -1.2 -1 -0.8 -0.6 -0.4 -0.2 0 CONTROL VOLTAGE (V) CONTROL VOLTAGE (V) m in a
Output IP3 @ 10 dBm
a 30 7 GHz 28 le g 26 b ) 12 GHz 24 ia (dBm 22 r IP3 a 20 V 16 GHz 18 16 -2 -1.8 -1.6 -1.4 -1.2 -1 -0.8 -0.6 CONTROL VOLTAGE (V) Inf F or o m rat ip o r n ifc ur e n ,is hd e e d lbiv y e Anry alo a g n D d evi cto es ips la beclie ev eo d rtd o e b r e sa: ccH ur iattte itaen M d reliic a r bl o e w . H a o v weev eC r, o n r o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other poration, 20 Alpha Road, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 rights of third parties that may result from its use. Specifications subject to change without notice. No Or P d hoe n r e O : 7 n- 81-li 3 n 2 e 9- a 4 t 7 0 www 0 • O . rdh e itt r o it n e li . n co e a m license is granted by implication or otherwise under any patent or patent rights of Analog Devices. t www.analog.com
6 - 4
Application Support: Phon Trademarks and registered trademarks are the property of their respective owners. e: 978-250-334 A 3 p p liocra t ia o pp n S s u @ p h por ittti : Pte. ho c n o e m : 1-800-ANALOG-D
