Datasheet AD605 (Analog Devices) - 5
DescriptionDual, Low Noise, Single-Supply Variable Gain Amplifier
Pages / Page24 / 5 — AD605. ABSOLUTE MAXIMUM RATINGS. Table 2. Parameter Rating. ESD CAUTION
RevisionF
File Format / SizePDF / 473 Kb
AD605 ABSOLUTE MAXIMUM RATINGS Table 2 Parameter Rating ESD CAUTION
Stresses above those listed under Absolute Maximum Ratings
Table 2.
may cause permanent damage to the device. This is a stress
Parameter Rating
rating only; functional operation of the device at these or any Supply Voltage +VS other conditions above those indicated in the operational Pin 12, Pin 13 (with Pin 4, Pin 5 = 0 V) 6.5 V section of this specification is not implied. Exposure to absolute Input Voltage Pin 1 to Pin 3, Pin 6 to Pin 9, Pin 16 VPOS, 0 V maximum rating conditions for extended periods may affect Internal Power Dissipation device reliability. 16-Lead PDIP 1.4 W 16-Lead SOIC_N 1.2 W Operating Temperature Range −40°C to +85°C
ESD CAUTION
Storage Temperature Range −65°C to +150°C Lead Temperature, Soldering 60 sec 300°C Thermal Resistance θJA 16-Lead PDIP 85°C/W 16-Lead SOIC_N 100°C/W Rev. F | Page 5 of 24 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS (PER CHANNEL) THEORY OF OPERATION DIFFERENTIAL LADDER (ATTENUATOR) AC COUPLING GAIN CONTROL INTERFACE FIXED GAIN AMPLIFIER AND INTERPOLATOR CIRCUITS—APPLYING AN ACTIVE FEEDBACK AMPLIFIER APPLICATIONS INFORMATION CONNECTING TWO AMPLIFIERS TO DOUBLE THE GAIN RANGE EVALUATION BOARD INPUT CONNECTIONS ADJUSTING GAIN, COMMON-MODE, AND REFERENCE LEVELS OUTPUT CONNECTIONS OUTLINE DIMENSIONS ORDERING GUIDE
