Datasheet AD603 (Analog Devices) - 10
DescriptionLow Noise, 90 MHz Variable Gain Amplifier
Pages / Page24 / 10 — AD603. Data Sheet. TA = 25°C RS = 50Ω RIN = 50Ω. RL = 100Ω TEST SETUP …
RevisionK
File Format / SizePDF / 802 Kb
AD603. Data Sheet. TA = 25°C RS = 50Ω RIN = 50Ω. RL = 100Ω TEST SETUP FIGURE 23. 30MHz. Bm) d (. 40MHz. L E V. T LE U TP. 70MHz. –40. –30. –20
AD603 Data Sheet TA = 25°C RS = 50Ω RIN = 50Ω RL = 100Ω TEST SETUP FIGURE 23 30MHz Bm) d ( 40MHz L E V T LE U TP 70MHz –40 –30 –20
AD603 Data Sheet 20 TA = 25°C RS = 50Ω RIN = 50Ω 18 RL = 100Ω TEST SETUP FIGURE 23 30MHz 16 Bm) d ( 40MHz L E V 14 T LE U TP 12 OU 70MHz 10 8
028
–40 –30 –20 INPUT LEVEL (dBm)
00539- Figure 28. Third-Order Intercept −10 dB/+30 dB Mode, Gain = 30 dB Rev. K | Page 10 of 24 Document Outline Features Applications General Description Functional Block Diagram Revision History Specifications Absolute Maximum Ratings ESD Caution Pin Configurations and Function Descriptions Typical Performance Characteristics Test Circuits Theory of Operation Noise Performance The Gain Control Interface Programming the Fixed-Gain Amplifier Using Pin Strapping Using the AD603 in Cascade Sequential Mode (Optimal SNR) Parallel Mode (Simplest Gain Control Interface) Low Gain Ripple Mode (Minimum Gain Error) Applications Information A Low Noise AGC Amplifier Caution Evaluation Board Outline Dimensions Ordering Guide
