Datasheet HMC900LP5E (Analog Devices) - 4
Description50 MHz Dual Baseband Programmable Low Pass Filter
Pages / Page26 / 4 — HMC900LP5E. 50 MHz DUAL PROGRAMMABLE. LOW PASS FILTER with DRIVER. Figure …
HMC900LP5E. 50 MHz DUAL PROGRAMMABLE. LOW PASS FILTER with DRIVER. Figure 1. Filter Attenuation. (all Bandwidths)
HMC900LP5E 50 MHz DUAL PROGRAMMABLE LOW PASS FILTER with DRIVER Figure 1 Filter Attenuation (all Bandwidths)
HMC900LP5E
v04.0811
50 MHz DUAL PROGRAMMABLE LOW PASS FILTER with DRIVER Figure 1. Filter Attenuation (all Bandwidths) Figure 2. Filter Noise Figure vs Bandwidth[1]
0 26 24 -20 3.5 MHz ) 0 dB Gain B ) 22 B (d -40 IN (d A E R +27C Bypass G 20 U R 3.5MHz +85C E IG T -60 5MHz -40C F IL 7MHz E F 10MHz 50 MHz IS 18 O 10 dB Gain 14MHz N 20MHz -80 28MHz 16 35MHz 50MHz -100 14 0.1 1 10 100 3.5 5 7 10 14 20 28 35 50 FREQUENCY (MHz) FILTER BANDWIDTH (MHz) 3
Figure 3. Filter Passband Gain Response Figure 4. Filter Output Noise
0.3 g 100 3.5MHz 0.2 3.5MHz 20MHz 7MHz 28MHz 5MHz 7MHz IN 5MHz 35MHz 10MHz 0.1 10MHz 50MHz ) 14MHz 14MHz z 20MHz s ) 28MHz 50 MHz B /rtH 0 35MHz V s 50 MHz (d 50MHz (n IN E e A -0.1 IS G O R N C E -0.2 T T 3.5 MHz U IL P F T O -0.3 U O 10 3.5 MHz R -0.4 -0.5 l P 1 10 100 0.001 0.01 0.1 1 10 100 FREQUENCY (MHz) FREQUENCY (MHz) a N Ig
Figure 5. Filter 3 dB Cutoff vs Figure 6. Filter Side Band Rejection vs
s
Temperature, 10 MHz Bandwidth Bandwidth
D 5 55 N +27C +85C a 0dB -40C ) c 10dB B B ) 0 (d 50 B N e IO (d T IN C s A E J G -3dB E R a E R T D IL -5 N 45 F A B E ID S IF / B -10 40 5 6 7 8 9 10 20 3.5 5 7 10 14 20 28 35 50 FREQUENCY (MHz) FILTER BANDWIDTH (MHz) [1] Measured with 100 Ω source impedance Information furnish F e o d r b y pArnic alo e g , D d evi ecleis vie s rby eli, ea ve n d d to tbo e apl cc a ur c at e e ao n r d d releiars ble ,. p Ho le we a vesr, en c o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other ontact Hittite Microwave Corporation: One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 2 Elizabeth Drive, Chelmsford, MA 01824 Phon rights of third parties that may result from its use. Specifications subject to change without notice. No e: 9 Ph 7 o 8 n - e 2 : 750 81- - 3 3 2 3 9- 4 4 3 7 0 Fax 0 • O : rd 9 e 7 r o8 nl-i2 n 50 e at -33 ww 7 w. 3 license is granted by implication or otherwise under any patent or patent rights of Analog Devices. analog.com
3 - 4
Order On- Trademarks and registered trademarks are the property of their respective owners. line at www.hi A tptiptliec.actio o m n Support: Phone: 1-800-ANALOG-D
