Datasheet HMC900LP5E (Analog Devices) - 10
Description50 MHz Dual Baseband Programmable Low Pass Filter
Pages / Page26 / 10 — HMC900LP5E. 50 MHz DUAL PROGRAMMABLE. LOW PASS FILTER with DRIVER. …
HMC900LP5E. 50 MHz DUAL PROGRAMMABLE. LOW PASS FILTER with DRIVER. Evaluation PCB. Table 6. Evaluation Order Information. 3 - 10
HMC900LP5E 50 MHz DUAL PROGRAMMABLE LOW PASS FILTER with DRIVER Evaluation PCB Table 6 Evaluation Order Information 3 - 10
HMC900LP5E
v04.0811
3 g IN s s e C O R The circuit board used in the application should use RF circuit design techniques. signal lines should have 50 l P Ohms impedance while the package ground leads and exposed paddle should be connected directly to the a ground plane similar to that shown. a sufficient number of via holes should be used to connect the top and N bottom ground planes. The evaluation circuit board shown is available from Hittite upon request. Ig s
D Item Contents Part Number N evaluation PCB Only HMC900lP5e evaluation PCB 131200-HMC900lP5e a HMC900lP5e evaluation PCB B UsB Interface Board evaluation Kit 130521-HMC900lP5e e 6’ UsB a Male to UsB B Female Cable CD ROM (Contains User Manual, evaluation PCB schematic, evaluation software) s a IF / B Information furnish F e o d r b y pArnic alo e g , D d evi ecleis vie s rby eli, ea ve n d d to tbo e apl cc a ur c at e e ao n r d d releiars ble ,. p Ho le we a vesr, en c o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other ontact Hittite Microwave Corporation: One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 2 Elizabeth Drive, Chelmsford, MA 01824 Phon rights of third parties that may result from its use. Specifications subject to change without notice. No e: 9 Ph 7 o 8 n - e 2 : 750 81- - 3 3 2 3 9- 4 4 3 7 0 Fax 0 • O : rd 9 e 7 r o8 nl-i2 n 50 e at -33 ww 7 w. 3 license is granted by implication or otherwise under any patent or patent rights of Analog Devices. analog.com
3 - 10
Order On- Trademarks and registered trademarks are the property of their respective owners. line at www.hi A tptiptliec.actio o m n Support: Phone: 1-800-ANALOG-D
