Datasheet HMC742ALP5E (Analog Devices)
Description0.5 dB LSB GaAs MMIC 6-Bit Digital Variable Gain Amplifier SMT, 0.07 - 4 GHz
Pages / Page12 / 1 — HMC742ALP5E. 0.5 dB LSB GaAs MMIC 6-BIT DIGITAL. VARIABLE GAIN AMPLIFIER, …
File Format / SizePDF / 769 Kb
HMC742ALP5E. 0.5 dB LSB GaAs MMIC 6-BIT DIGITAL. VARIABLE GAIN AMPLIFIER, 70 MHz - 4 GHz. Typical Applications. Features
Datasheet HMC742ALP5E Analog Devices
HMC742ALP5E
v01.1213
0.5 dB LSB GaAs MMIC 6-BIT DIGITAL VARIABLE GAIN AMPLIFIER, 70 MHz - 4 GHz Typical Applications Features
The HMC742ALP5E is ideal for: -19.5 to 12 dB Gain Control in 0.5 dB Steps T • Cel ular/3G Infrastructure Power-up State Selection M • WiBro / WiMAX / 4G High Output IP3: +39 dBm • Microwave Radio & VSAT TTL/CMOS Compatible L - S Serial, Paral el, or latched Paral el Control • Test Equipment and Sensors ±0.25 dB Typical Gain Step Error ITA • IF & RF Applications Single +5V Supply IG 32 Lead 5x5 mm SMT Package: 25 mm2
The HMC742ALP5E is a digital y control ed variable S - D gain amplifier which operates from 70 MHz to 4 R GHz, and can be programmed to provide from -19.5 IE dB attenuation, to 12 dB of gain, in 0.5 dB steps. The HMC742ALP5E delivers noise figure of 4 dB LIF in its maximum gain state, with output IP3 of up to P +39 dBm in any state. The dual mode gain control M interface accepts either a three-wire serial input or a 6 bit paral el word. The HMC742ALP5E also features a IN A user selectable power up state and a serial output for A cascading other serial y controlled Hittite components. The HMC742ALP5E is housed in an RoHS compliant 5x5 mm QFN leadless package, and requires minimal LE G external components. B
Electrical Specifications, T = +25° C, 50 Ohm System Vdd = +5V, Vs= +5V
IA
A
R Min. Typ. Max. Min. Typ. Max. Units Parameter A 70 - 1000 500 - 4000 MHz V Gain (Maximum Gain State) 12 10 dB Gain Control Range 31.5 31.5 dB Input Return Loss 15 12 dB Output Return Loss 14 10 dB 70 MHz - 350 MHz Gain Accuracy: (Referenced to Maximum Gain State) ± (0.3 + 5% of relative gain setting) Max. ± (0.3 + 4% of relative gain setting) Max. All Gain States 350 MHz - 1000 MHz dB ± (0.3 + 6% of relative gain setting) Max. Output Power for 1 dB Compression 21.5 22 dBm Output Third Order Intercept Point 39 39 dBm (Two-Tone Output Power= 12 dBm Each Tone) Noise Figure (Max Gain State) 4 4.5 dB Switching Characteristics tRISE, tFall (10 / 90% RF) 70 70 ns tON, tOFF (Latch Enable to 10 / 90% RF) 140 140 ns Supply Current (Amplifier) Is 130 150 175 130 150 175 mA Supply Current (Controller) Idd 1.0 2.5 3.5 1.0 2.5 3.5 mA I F nf o or r p mati r o in cfe ur , d nish e e l d iv b e y r A y a nalo n g d t Devi o p ces i la s c bele o ieve rd d t e o rbs e : H acc iutrtatite e M and ic reli rao bl w e. a H v o e C wever o , nrp o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other oration, 2 Elizabeth Drive, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 O rights of third parties that may result from its use. Specifications subject to change without notice. No rd Phoe n r O e: 7 n- 81-li 3 n 2 e a 9-4 t w 70 ww 0 • O . rdh e itt r o it nle i . n co e a m
1
license is granted by implication or otherwise under any patent or patent rights of Analog Devices. t www.analog.com Application Support: Phon Trademarks and registered trademarks are the property of their respective owners. e: 978-250-334 A 3 o pplic r a atio pp n S s u @ p h por ittti : Pte ho.c n o e m : 1-800-ANALOG-D
