Datasheet HMC681ALP5E (Analog Devices)
Description0.5 dB LSB GaAs MMIC 6-BIT Digital Variable Gain Amplifier with Serial Control, DC - 1 GHz
Pages / Page11 / 1 — HMC681ALP5E. 0.5 dB LSB GaAs MMIC 6-BIT DIGITAL VARIABLE GAIN. AMPLIFIER …
File Format / SizePDF / 825 Kb
HMC681ALP5E. 0.5 dB LSB GaAs MMIC 6-BIT DIGITAL VARIABLE GAIN. AMPLIFIER w/ SERIAL CONTROL, DC - 1 GHz. Typical Applications
Datasheet HMC681ALP5E Analog Devices
HMC681ALP5E
v00.0113
0.5 dB LSB GaAs MMIC 6-BIT DIGITAL VARIABLE GAIN AMPLIFIER w/ SERIAL CONTROL, DC - 1 GHz Typical Applications Features
The HMC681ALP5E is ideal for: +13.5 dB to +45 dB Gain Control in 0.5 dB Steps T • IF & RF Applications High Output IP3: +36 dBm M • Cel ular/3G Infrastructure ±0.25 dB Typical Gain Step Error • WiBro / WiMAX / 4G Single +5V Supply L - S • Microwave Radio & VSAT 32 Lead 5x5 mm SMT Package: 25 mm2 ITA • Test Equipment and Sensors IG
The HMC681ALP5E is a digital y control ed variable gain amplifier which operates from DC to 1 GHz, S - D and can be programmed to provide anywhere from R 13.5 dB, to 45 dB of gain, in 0.5 dB steps. The IE HMC681ALP5E delivers noise figure of 2.8 dB in its maximum gain state, with output IP3 of up to +36 LIF dBm in any state. This serial y control ed digital VGA P incorporates off chip AC ground capacitors for near M DC operation, making it suitable for a wide variety of RF and IF applications. The HMC681ALP5E is housed in a RoHS compliant 5x5 mm QFN leadless package, IN A and provides the user with a highly integrated solution. A This functionality is also available with paral el control as the HMC626ALP5E. LE G B IA
Electrical Specifications, T = +25° C, Vdd = Vs= P/S= +5V A
R A Min. Typ. Max. Min. Typ. Max. Units Parameter V 50 - 350 350 - 1000 MHz Gain (Maximum Gain State) 40 45 30 40 dB Gain Control Range 31.5 31.5 dB Input Return Loss 25 30 dB Output Return Loss 20 17 dB Gain Setting Accuracy: (Referenced to Maximum Gain State) ± (0.15 + 3% of Relative Gain Setting) Max. ± (0.15 + 3% of Relative Gain Setting) Max. dB All Gain States Output Power for 1 dB Compression 20 19 dBm Output Third Order Intercept Point 38 36 dBm (Two-Tone Output Power= 5 dBm Each Tone) Noise Figure 2.7 2.8 dB Switching Characteristics tRISE, tFALL (10/90% RF) 60 60 ns tON, tOFF (50% CTL to 10/90% RF) 120 120 ns Total Supply Current (Idd + 2*Is) 184.5 225 184.5 225 mA I F nf o or r p mati r o in cfe ur , d nish e e l d iv b e y r A y a nalo n g d t Devi o p ces i la s c bele o ieve rd d t e o rbs e : H acc iutrtatite e M and ic reli rao bl w e. a H v o e C wever o , nrp o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other oration, 2 Elizabeth Drive, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 O rights of third parties that may result from its use. Specifications subject to change without notice. No rd Phoe n r O e: 7 n- 81-li 3 n 2 e a 9-4 t w 70 ww 0 • O . rdh e itt r o it nle i . n co e a m
1
license is granted by implication or otherwise under any patent or patent rights of Analog Devices. t www.analog.com Application Support: Phon Trademarks and registered trademarks are the property of their respective owners. e: 978-250-334 A 3 o pplic r a atio pp n S s u @ p h por ittti : Pte. ho c n o e m : 1-800-ANALOG-D
