Datasheet HMC681ALP5E (Analog Devices) - 3
Description0.5 dB LSB GaAs MMIC 6-BIT Digital Variable Gain Amplifier with Serial Control, DC - 1 GHz
Pages / Page11 / 3 — HMC681ALP5E. 0.5 dB LSB GaAs MMIC 6-BIT DIGITAL VARIABLE GAIN. AMPLIFIER …
File Format / SizePDF / 825 Kb
HMC681ALP5E. 0.5 dB LSB GaAs MMIC 6-BIT DIGITAL VARIABLE GAIN. AMPLIFIER w/ SERIAL CONTROL, DC - 1 GHz. 50 to 350 MHz Tuning
HMC681ALP5E 0.5 dB LSB GaAs MMIC 6-BIT DIGITAL VARIABLE GAIN AMPLIFIER w/ SERIAL CONTROL, DC - 1 GHz 50 to 350 MHz Tuning
HMC681ALP5E
v00.0113
0.5 dB LSB GaAs MMIC 6-BIT DIGITAL VARIABLE GAIN AMPLIFIER w/ SERIAL CONTROL, DC - 1 GHz 50 to 350 MHz Tuning Relative Phase vs. Frequency Step Error vs. Frequency
T (Only Major States are Shown) (Only Major States are Shown) M 60 1 0.8 ) 40 0.6 g e (d 8 dB B) 0.4 L - S 31.5 dB (d IL 20 R 0.2 ASE O R PH 0 ER ITA IVE 0 -0.2 EP AT ST -0.4 0.5 - 16 dB IG EL R 16 dB 16 dB -20 -0.6 8 dB -0.8 31.5 dB -40 -1 0.05 0.1 0.15 0.2 0.25 0.3 0.35 0.05 0.1 0.15 0.2 0.25 0.3 0.35 S - D FREQUENCY (GHz) FREQUENCY (GHz) R IE
Output P1dB Output IP3 @ 5 dBm Output Power per
LIF (Major States shown are IL through 16 dB))
Tone
P (Major States shown are IL through 16 dB) 24 45 M 43 22 IL IN A ) m 41 m A (dB 20 (dB 3 1dB IP 39 P 16 dB 18 37 LE G 16 dB B 16 35 0.05 0.1 0.15 0.2 0.25 0.3 0.35 0.05 0.1 0.15 0.2 0.25 0.3 0.35 IA FREQUENCY (GHz) FREQUENCY (GHz) R A V I F nf o or r p mati r o in cfe ur , d nish e e l d iv b e y r A y a nalo n g d t Devi o p ces i la s c bele o ieve rd d t e o rbs e : H acc iutrtatite e M and ic reli rao bl w e. a H v o e C wever o , nrp o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other oration, 2 Elizabeth Drive, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 O rights of third parties that may result from its use. Specifications subject to change without notice. No rd Phoe n r O e: 7 n- 81-li 3 n 2 e a 9-4 t w 70 ww 0 • O . rdh e itt r o it nle i . n co e a m
3
license is granted by implication or otherwise under any patent or patent rights of Analog Devices. t www.analog.com Application Support: Phon Trademarks and registered trademarks are the property of their respective owners. e: 978-250-334 A 3 o pplic r a atio pp n S s u @ p h por ittti : Pte. ho c n o e m : 1-800-ANALOG-D
