Datasheet ADL5240 (Analog Devices) - 10
Description100 MHz TO 4000 MHz RF/IF Digitally Controlled VGA
Pages / Page28 / 10 — ADL5240. Data Sheet. TYPICAL PERFORMANCE CHARACTERISTICS. ) m B. OIP3. , …
ADL5240. Data Sheet. TYPICAL PERFORMANCE CHARACTERISTICS. ) m B. OIP3. , d. 3 (d. , O B. GAIN. 3 (. OIP. , G. P1dB. IGU. F E IS. +85°C. NOISE FIGURE
ADL5240 Data Sheet TYPICAL PERFORMANCE CHARACTERISTICS ) m B OIP3 , d 3 (d , O B GAIN 3 ( OIP , G P1dB IGU F E IS +85°C NOISE FIGURE
ADL5240 Data Sheet TYPICAL PERFORMANCE CHARACTERISTICS 45 30 45 ) m B 40 OIP3 , d 28 40 B 35 3 (d 26 35 IP 30 , O B ) ) m m 1d 25 GAIN 24 30 B B P d , ( d IN B 3 ( 20 A d 22 25 OIP , G P1 E 15 R P1dB 20 20 IGU 10 F E IS 18 15 5 +85°C O NOISE FIGURE N +25°C –40°C 0 16 10
6
0 0.4 0.8 1.2 1.6 2.0 2.4 2.8 3.2 3.6 4.0
03 0
-00 0- 0
FREQUENCY (GHz)
43 943
FREQUENCY (GHz)
0 09 Figure 3. AMP: Gain, P1dB, OIP3 at POUT = 4 dBm/Tone and Noise Figure vs. Figure 6. AMP: OIP3 at POUT = 4 dBm/Tone and P1dB vs. Frequency and Frequency Temperature
21.0 46 1960MHz 2140MHz 44 20.5 943MHz 42 748MHz –40°C 40 20.0 38 ) ) B 19.5 +25°C m 36 d B 450MHz ( d IN +85°C 34 3 ( 19.0 GA 32 OIP 2630MHz 30 18.5 28 150MHz 3600MHz 18.0 26 24 17.5
4
22 0 0.4 0.8 1.2 1.6 2.0 2.4 2.8 3.2 3.6
-00
–5 –3 –1 1 3 5 7 9 11 13 15 17
007 30
FREQUENCY (GHz)
094
POUT PER TONE (dBm)
09430- Figure 4. AMP: Gain vs. Frequency and Temperature Figure 7. AMP: OIP3 vs. POUT and Frequency
0 4.5 –5 4.0 –10 +85°C B) S22 ) d B 3.5 ( –15 d S ( R E RE T U +25°C E –20 3.0 IG M S12 F E ARA –25 IS -P 2.5 –40°C S NO –30 2.0 –35 S11 –40
5
1.5
8
0.1 0.5 0.9 1.3 1.7 2.1 2.5 2.9 3.3 3.7 4.1
00
00
FREQUENCY (GHz) FREQUENCY (GHz)
09430- 09430- Figure 5. AMP: Input Return Loss (S11), Output Return Loss (S22), and Reverse Figure 8. AMP: Noise Figure vs. Frequency and Temperature Isolation (S12) vs. Frequency Rev. A | Page 10 of 28 Document Outline Features Applications General Description Functional Block Diagram Revision History Specifications Absolute Maximum Ratings ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Applications Information Basic Layout Connections Amplifier Bias Digital Step Attenuator Bias Amplifier RF Input Interface Amplifier RF Output Interface DSA RF Input Interface DSA RF Output Interface DSA SPI Interface SPI Timing SPI Timing Sequence Loop Performance Amplifier Drive Level for Optimum ACLR Thermal Considerations Evaluation Board Outline Dimensions Ordering Guide
