Datasheet HMC680LP4, 680LP4E (Analog Devices) - 3
DescriptionBiCMOS 5-Bit Digital Variable Gain Amplifier SMT, 30 - 400 MHz
Pages / Page8 / 3 — HMC680LP4 / 680LP4E. BiCMOS MMIC 5-BIT DIGITAL. VARIABLE GAIN AMPLIFIER, …
File Format / SizePDF / 555 Kb
HMC680LP4 / 680LP4E. BiCMOS MMIC 5-BIT DIGITAL. VARIABLE GAIN AMPLIFIER, 30 - 400 MHz. Relative Phase vs. Frequency
HMC680LP4 / 680LP4E BiCMOS MMIC 5-BIT DIGITAL VARIABLE GAIN AMPLIFIER, 30 - 400 MHz Relative Phase vs Frequency
HMC680LP4 / 680LP4E
v03.0609
BiCMOS MMIC 5-BIT DIGITAL VARIABLE GAIN AMPLIFIER, 30 - 400 MHz Relative Phase vs. Frequency Step Accuracy vs. Frequency
(Only Major States are Shown) 2 80 1.5 16 dB 60 ) 1 8 dB 16, 23 dB (deg) 40 (dB E 0.5 R S A O H 8 dB R 0 R P 20 E E P IV E -0.5 T T 0 S LA E -1 1, 2, 4, 23 dB R -20 -1.5 1, 2, 4 dB -2 -40 0 0.1 0.2 0.3 0.4 0.5 0.6 0 0.1 0.2 0.3 0.4 0.5 0.6 12 FREQUENCY (GHz) FREQUENCY (GHz)
Output IP3 vs. Temperature
t (+5 dBm Output Power Per Tone)
Output P1dB vs. Temperature
m 50 40 s 45 35 40 30 l - 35 ) 30 25 (dBm (dBm) 20 ita 25 IP3 20 P1dB 15 ig -40C 15 -40C +25C +25C 10 +85C 10 +85C 5 5 0 s - d 0 0 0.1 0.2 0.3 0.4 0.5 0.6 0 0.1 0.2 0.3 0.4 0.5 0.6 r FREQUENCY (GHz) FREQUENCY (GHz) ie
Output IP2 vs. Temperature
lif
Noise Figure vs. Attenuation State
(+5 dBm Output Power Per Tone) p 25 100 m 20 8dB 80 ) in a (dB E ) R 15 4dB a 60 U IG 2dB (dBm F 1dB E 10 IP2 40 IS O N -40C le g 5 20 +25C +85C b I.L. ia 0 0 0 0.2 0.4 0.6 0.8 1 0 0.1 0.2 0.3 0.4 0.5 0.6 r FREQUENCY (GHz) FREQUENCY (GHz) a V Inf F or o m rat ip o r n ifc ur e n ,is hd e e d lbiv y e Anry alo a g n D d evi cto es ips la beclie ev eo d rtd o e b r e sa: ccH ur iattte itaen M d reliic a r bl o e w . H a o v weev eC r, o n r o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other poration, 20 Alpha Road, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106
12 - 3
Phone: 978-250-3343 Fax: 978-250-3373 rights of third parties that may result from its use. Specifications subject to change without notice. No Or P d hoe n r e O : 7 n- 81-li 3 n 2 e 9- a 4 t 7 0 www 0 • O . rdh e itt r o it n e li . n co e a m license is granted by implication or otherwise under any patent or patent rights of Analog Devices. t www.analog.com Application Support: Phon Trademarks and registered trademarks are the property of their respective owners. e: 978-250-334 A 3 p p liocra t ia o pp n S s u @ p h por ittti : Pte. ho c n o e m : 1-800-ANALOG-D
