Datasheet AL5814Q (Diodes) - 6
ManufacturerDiodes
DescriptionAutomotive Compliant 60V LED Linear Dimmable LED Controller
Pages / Page14 / 6 — AL5814Q. Typical Performance Characteristics. Supply Current vs. T. …
File Format / SizePDF / 561 Kb
AL5814Q. Typical Performance Characteristics. Supply Current vs. T. emperature. Quiescent Current v. s. Temperature. E N
AL5814Q Typical Performance Characteristics Supply Current vs T emperature Quiescent Current v s Temperature E N
(VCC = 12V, TA = +25°C, unless otherwise specified.)
Supply Current vs. T emperature Quiescent Current v s. Temperature
10.6 0.34 0.32 10.5 0.30 10.4 0.28 ) 10.3 ) A A 0.26 m m 10.2 ( 0.24 rent
T
rent 10.1 0.22 ur ur C 10.0 y C 0.20
UC
cent 0.18 9.9 uppl es S ui 0.16 9.8 Q
OD
0.14
R
9.7 0.12 9.6
P
0.10 -40 -20 0 20 40 60 80 100 120 -40 -20 0 20 40 60 80 100 120
W
Temperature (oC) Temperature (oC)
E N VUVLO vs. Temperature V REF vs. Temp erature
4.5 0.406 4.4 0.404 4.3 4.2 0.402 4.1 0.400 V) ( 4.0 V) ( LO F 3.9 V UV 0.398 V RE 3.8 0.396 3.7 VUVLO_H V 3.6 0.394 UVLO_L 3.5 -40 -20 0 20 40 60 80 100 120 0.392 -40 -20 0 20 40 60 80 100 120 Temperature (oC) Temperature (oC)
ISFAULT vs. Temperature I VFAULT vs. Temp erature
-45.0 -12.6 -45.5 -12.8 µA) -46.0 µA) ( in ( -46.5 LT -13.0 P U A LT F -47.0 U A S -13.2 F -47.5 V from -13.4 -48.0 from rent ur -48.5 rent -13.6 ur ce C -49.0 our ce C -13.8 S -49.5 our S -50.0 -14.0 -40 -20 0 20 40 60 80 100 120 -40 -20 0 20 40 60 80 100 120 Temperature (oC) Temperature (oC) AL5814Q 6 of 14 April 2019 Document number: DS41792 Rev. 1 - 2
www.diodes.com
© Diodes Incorporated Document Outline Pin Assignments Description Applications Features Package Outline Dimensions Suggested Pad Layout
