Datasheet VEML6035 (Vishay) - 2
ManufacturerVishay
DescriptionLow Power, High Sensitivity, I²C, Accuracy Ambient Light Sensor
Pages / Page15 / 2 — VEML6035. ABSOLUTE MAXIMUM RATINGS. PARAMETER. TEST CONDITION. SYMBOL. …
File Format / SizePDF / 222 Kb
VEML6035. ABSOLUTE MAXIMUM RATINGS. PARAMETER. TEST CONDITION. SYMBOL. MIN. MAX. UNIT. BASIC CHARACTERISTICS. TYP. Notes
VEML6035 ABSOLUTE MAXIMUM RATINGS PARAMETER TEST CONDITION SYMBOL MIN MAX UNIT BASIC CHARACTERISTICS TYP Notes
VEML6035
(Tamb = 25 °C, unless otherwise specified)
PARAMETER TEST CONDITION SYMBOL MIN. MAX. UNIT
Supply voltage VDD 0 4 V Operation temperature range Tamb -25 +85 °C Storage temperature range Tstg -25 +85 °C Total power dissipation Tamb ≤ 25 °C Ptot - 50 mW Junction temperature Tj - 85 °C
PARAMETER TEST CONDITION SYMBOL MIN. TYP. MAX. UNIT
Supply voltage VDD 1.7 1.8 3.6 V Shut down current (2) VDD = 1.8 V Isd - 0.5 - μA VDD = 1.8 V, CHANNEL_EN = 0 (ALS only) IDD - 170 - μA Operation mode current (1) VDD = 1.8 V, CHANNEL_EN = 1 I (ALS and WHITE) DD - 225 - μA I2C clock rate range fSCL 10 - 400 kHz I2C bus input H-level range VDD = 1.8 V Vih 1.2 - VDD V I2C bus input L-level range VDD = 1.8 V Vil 0 - 0.4 V Output low voltage SDA 3 mA sink current Vol 0 - 0.4 V Digital resolution (LSB count) With GAIN = 1, DG = 1, SENS = 0 - 0.0004 - lx/step Detectable minimum illuminance (3) With GAIN = 1, DG = 1, SENS = 0 EV min. - 0.004 - lx Detectable maximum illuminance With GAIN = 0, DG = 0, SENS = 1 EV max. - 6710 - lx Dark offset (4) With GAIN = 1, DG = 1, SENS = 0 - - 5 step
Notes
(1) Light source: white LED (2) Light conditions: dark (3) The part has a typical zero offset of 10 counts at the set max. resolution of 0.0004lx/step, so the first valid measurement will be at an illuminance of 0.004lx (typ.) (4) The dark offset can be above or below 0
CIRCUIT BLOCK DIAGRAM
VDD Temperature compensation SCL Low pass filter Output buffer SDA with Timing I2C interface controller INT Oscillator GND Fig. 1 - Block Diagram Rev. 1.0, 12-Mar-2019
2
Document Number: 84889 For technical questions, contact: sensorstechsupport@vishay.com THIS DOCUMENT IS SUBJECT TO CHANGE WITHOUT NOTICE. THE PRODUCTS DESCRIBED HEREIN AND THIS DOCUMENT ARE SUBJECT TO SPECIFIC DISCLAIMERS, SET FORTH AT www.vishay.com/doc?91000
