Datasheet VIPER26K (STMicroelectronics) - 7
Description1050 V High voltage converter
Pages / Page28 / 7 — VIPer26K. Electrical characteristics. Table 5. Power section. Symbol. …
VIPer26K. Electrical characteristics. Table 5. Power section. Symbol. Parameter. Test conditions. Min. Typ. Max. Unit
VIPer26K Electrical characteristics Table 5 Power section Symbol Parameter Test conditions Min Typ Max Unit
VIPer26K Electrical characteristics 3 Electrical characteristics
(TJ = -40 to 125°C, VDD = 14V; unless otherwise specified.)
Table 5. Power section Symbol Parameter Test conditions Min. Typ. Max. Unit.
ID = 1 mA, VBVDSS Breakdown voltage VCOMP = GND, 1.05 kV TJ = 25°C VDRAIN = 1050V, I Drain-source leakage DSS V 29 μA current COMP = GND, TJ = 25°C IDRAIN = 0.2 A; 7 TJ = 25 °C R Drain-Source ON state DS(on) resistance IDRAIN = 0.2 A; 14 TJ = 125 °C
Table 6. Supply section Symbol Parameter Test conditions Min. Typ. Max. Unit High voltage start-up current source
ID = 1 mA, Startup breakdown drain- VVDSS_SU V 1.05 kV source voltage COMP = GND, TJ = 25°C VHV_START Drain-source start voltage 38 60 V VDRAIN = 50 V to Charging current during IDDch1 1.05 kV, -0.6 -1.8 mA startup VDD = 4 V VDRAIN = 50 V to Charging current in self- IDDch2 1.05 kV, -7 -13 mA supply VDD = 9 V falling edge
IC supply and consumptions
VDD Operating voltage range 11.5 23.5 V VDDclamp VDD clamp voltage IDD = 15 mA 23.5 V VDDon VDD start up threshold 12 13 14 V DS12978 Rev 1 7/28 28 Document Outline Figure 1. Basic application schematic 1 Pin setting Figure 2. Connection diagram Table 1. Pin description 2 Electrical and thermal ratings Table 2. Absolute maximum ratings Table 3. Thermal data Figure 3. RthJA Table 4. Avalanche characteristics 3 Electrical characteristics Table 5. Power section Table 6. Supply section Table 7. Controller section 3.1 Typical electrical characteristics Figure 4. IDLIM vs. Tj Figure 5. FOSC vs. Tj Figure 6. VHV_START vs. Tj Figure 7. VREF_FB vs. Tj Figure 8. IDD0 vs. Tj Figure 9. IDD1 vs. Tj Figure 10. GM vs. Tj Figure 11. HCOMP vs. Tj Figure 12. ICOMP(source/sink) vs. Tj Figure 13. ICOMP(max source) vs. Tj Figure 14. Power MOSFET capacitances variation vs. VDS @ VGS=0, f=1MHz Figure 15. VBVDSS vs. TJ .. Figure 16. RDS(on) vs. Tj Figure 17. Maximum avalanche energy vs. Tj Figure 18. SOA SSOP10 package 4 General description 4.1 Block diagram Figure 19. Block diagram 4.2 Typical power capability Table 8. Typical power 4.3 Primary MOSFET 4.4 High voltage startup Figure 20. Timing diagram: normal power-up and power-down sequences 4.5 Oscillator 4.6 Soft-start 4.7 Current limit set point 4.8 FB pin and COMP pin Figure 21. Feedback circuit Figure 22. COMP pin vs. IDLIM 4.9 Burst mode Figure 23. Load-dependent operating modes: timing diagram 4.10 Automatic auto restart after overload or short-circuit Figure 24. Timing diagram: OLP sequence 4.11 Open loop failure protection 4.12 Thermal shutdown Figure 25. Timing diagram: OLP sequence 5 Application information Figure 26. Typical isolated flyback configuration with secondary regulation Figure 27. Typical isolated flyback configuration with primary regulation Figure 28. Typical non isolated flyback configuration Figure 29. Ultra wide range Buck configuration 5.1 Layout guidelines and design recommendations Figure 30. Recommended routing for flyback converter Figure 31. Recommended routing for Buck converter 6 Package information 6.1 SO16N package information Figure 32. SO16N package outline Table 9. SO16N mechanical data 7 Order code Table 10. Order codes 8 Revision history Table 11. Document history
