Datasheet 5X1503 (IDT)
Manufacturer | IDT |
Description | MicroClock Programmable Clock Generator with Embedded Crystal |
Pages / Page | 28 / 1 — MicroClock Programmable Clock. 5X1503. Generator. Datasheet. Description. … |
Revision | 20190619 |
File Format / Size | PDF / 401 Kb |
MicroClock Programmable Clock. 5X1503. Generator. Datasheet. Description. Features. Output Features. Key Specifications. 5X1503 Base
link to page 26
MicroClock Programmable Clock 5X1503 Generator Datasheet Description Features
The 5X1503 is a series of small form factor programmable clock ▪ Proactive Power Saving (PPS) features save power during the generators intended for low-power, consumer, battery powered end device power-down mode applications, wearable and smart devices. ▪ Dynamic Frequency Control (DFC) feature allows programming The device is a 1 PLL + DCO architecture design with one up to 4 difference frequencies that switch dynamically embedded crystal. The device is OTP programmable, al owing for ▪ Programmable output clock amplitude (1V, 1.1V, 1.2V and up to 3 unique frequency outputs. The 5X1503 has built-in unique 1.8V) to support low swing clock requirement features such as Proactive Power Saving (PPS) and a low power ▪ Dedicated 32kHz output with 6 clock amplitude options DCO to support system date/time keeping clock at 32.768kHz. (5X1503L) Dynamic Frequency Control (DFC) supports dynamical y changing ▪ Integrated crystal; no external input source requirement between four different PLL frequencies via external requests with ▪ control ed frequency changes, reducing frequency overshoot and Configurable through I2C or OTP programming undershoot (ORT). The 5X1503S device can also support a ▪ Spread spectrum clock support (5X1503S) spread clock for EMI reduction. For a description of terms and ▪ 1.8V operating supply voltage their functions, see Glossary of Features. ▪ 2 × 2 mm 10-VFQFPN package An internal OTP memory allows the user to store up to four independent configurations that can be loaded on power-up
Output Features
without programming. It can then be reprogrammed again through the I2C interface. ▪ 3 LVCMOS outputs, 1MHz–100MHz or 32.768kHz ▪ Low-power 32.768kHz clock supported The 5X1503 supports three LVCMOS type outputs. Two outputs have programmable amplitude. A low-power 32.768kHz clock is supported with only less than 1.5μA current consumption for
Key Specifications
system RTC reference clock needs. ▪ Output cycle-cycle jitter: 50ps (typ) ▪ Low power-on ful y active mode: 2mA (typ)
5X1503 Base
▪ Low-power 32.768kHz < 1.0μA (5X1503L)
Number Description VCO Range (MHz)
5X1503 Standard, Integrated Crystal 50 – 130 5X1503L Ultra Low-power, Integrated Crystal 50 – 130 5X1503S Spread Clock, Integrated Crystal 500 –1100
Typical Applications
▪ SmartDevice ▪ Handheld ▪ Wearable applications ▪ Portable Consumer applications ©2019 Integrated Device Technology, Inc 1 June 19, 2019 Document Outline Description Typical Applications Features Output Features Key Specifications Block Diagram Pin Assignments Figure 1. Pin Assignments for 2.0 × 2.0 mm 10-VFQFPN Package Pin Descriptions Table 1. Pin Descriptions Device Feature and Function DFC – Dynamic Frequency Control Figure 2. DFC Function Block Diagram Table 2. DFC Function Priority DFC Function Programming PPS – Proactive Power Saving Function Figure 3. PPS Function Block Diagram Figure 4. PPS Assertion/Deassertion Timing Chart PPS Function Programming Output Divider Selection Table 3. Output Divider Selection Device Output Support 5X1503 5X1503L 5X1503S Input Pin Function Table 4. OE Pin Function Table 5. OE Pin Function Summary Table 6. PD# Priority Spread Spectrum Spread Spectrum Digital Spread Spectrum Figure 5. Digital Spread Spectrum Absolute Maximum Ratings Table 7. Absolute Maximum Ratings Thermal Characteristics Table 8. Thermal Characteristics Recommended Operating Conditions Table 9. Recommended Operating Conditions Crystal Characteristics Table 10. Embedded Crystal Characteristics DC Electrical Characteristics Table 11. DC Electrical Characteristics – Current Table 12. DC Electrical Characteristics – Input and Output Voltage AC Electrical Characteristics Table 13. AC Timing Electrical Characteristics I2C Bus DC Characteristics Table 14. I2C Bus DC Characteristics Table 15. I2C Bus AC Characteristics Spread Spectrum Generation Specifications Table 16. Spread Spectrum Generation Specifications (5X1503S only) General I2C Interface Information How to Write How to Read Glossary of Features Table 17. Glossary of Features Package Outline Drawings Ordering Information Marking Diagrams Revision History
