Datasheet AP3917B (Diodes) - 4
ManufacturerDiodes
DescriptionUniversal AC High Voltage Step Down Power Switcher
Pages / Page12 / 4 — AP3917B. Electrical Characteristics. Symbol. Parameter. Condition. Min. …
File Format / SizePDF / 591 Kb
AP3917B. Electrical Characteristics. Symbol. Parameter. Condition. Min. Typ. Max. Unit. HV Pin Startup Current Source
AP3917B Electrical Characteristics Symbol Parameter Condition Min Typ Max Unit HV Pin Startup Current Source
(VBP = 8.2V, -40C <TA<+125C, unless otherwise specified.)
IHV HV Supply Current VBP = 7V, VDRAIN = 100V — 3.5 — mA VBP= 8.7V, VDRAIN = I — LEAK Leakage Current of Drain Pin 10 12 µA 400V, TA = +25°C
VBP Voltage Management
V V BP Increasing Level at which HV Supply is BP_HVOFF — 8.1 8.5 8.8 V OFF V V BP Decreasing Level at which HV Supply is BP_HVON — 7.8 8.2 8.6 V ON VBP_HYS VBP Hysteresis (VBP_HVOFF- VBP_HVON) — — 280 — mV VBP_UVLO VBP Minimum Operating Voltage TA = +25°C — 6.5 — V VBP_RESTART VBP Restart Voltage — — 4.5 — V V V I BP Operating Current with MOSFET BP = 8.5V, f = 37kHz, BP1 — — 350 µA Switching D = 40%, TA = +25°C IBP2 VBP Quiescent Current with No Switching TA = +25°C — 110 200 µA IBP_LATCH VBP Latch Off-Current VBP = 8.8V, TA = +25°C — 26 — µA
Internal MOSFET
VDS Breakdown Voltage (Note 5) TA = +25°C 650 — — V TA = +25°C — — 16 RDS(ON) ON Resistance Ω TA = +125°C — — 30
Internal Current Sense
IPK_MAX Maximum Peak Current TA = +25°C 230 280 336 mA tLEB1 Leading-Edge Blanking TA = +25°C — 250 400 ns ISCP Current Set Point for Short Circuit Protection TA = +25°C — 390 468 mA Leading-Edge Blanking for Short Circuit tLEB2 T Protection A = +25° C — 200 — ns
Feedback Input (FB Pin)
tMINOFF Minimum Off-Time TA = +25°C 12.5 17.5 22.5 µs VFB MOSFET Feedback Switch-On Threshold — 2.4 2.5 2.6 V Overload Protection Feedback Trigger VFB_OLP — 1.56 1.7 1.84 V Threshold tOLP Overload Protection Delay Time f = 36kHz — 170 — ms VOLD Open-Loop Detection Voltage TA = +25°C — 60 — mV tOLD Open-Loop Detection Blanking Time f = 15kHz, TA = +25°C — 4.3 — ms
Over Temperature Protection
TOTP Thermal Shutdown Threshold — +135 +150 +165 °C Note: 5. The drain-source voltage is 80% of VDS in the aging condition. AP3917B 4 of 12 May 2019 Document number: DS41277 Rev. 5 - 2
www.diodes.com
© Diodes Incorporated
