Datasheet CA139, CA139A, CA239, CA339, LM339, LM2901, LM3302 (Intersil)
Manufacturer | Intersil |
Description | Quad Voltage Comparators for Industrial, Commercial and Military Applications |
Pages / Page | 6 / 1 — CA139, CA139A, CA239, CA339,. LM339, LM2901, LM3302. Data Sheet. October … |
File Format / Size | PDF / 67 Kb |
CA139, CA139A, CA239, CA339,. LM339, LM2901, LM3302. Data Sheet. October 1999. File Number. 795.6
![Datasheet CA139, CA139A, CA239, CA339, LM339, LM2901, LM3302 Intersil](https://www.rlocman.ru/datasheet/img.php?di=166863)
CA139, CA139A, CA239, CA339, LM339, LM2901, LM3302 Data Sheet October 1999 File Number 795.6 Quad Voltage Comparators for Industrial, Features Commercial and Military Applications
• Operation from Single or Dual Supplies The devices in this series consist of four independent single • Common Mode Input Voltage Range to GND or dual supply voltage comparators on a single monolithic substrate. The common mode input voltage range includes • Output Voltage Compatible with TTL, DTL, ECL, ground even when operated from a single supply, and the MOS and CMOS low power supply current drain makes these comparators • Differential Input Voltage Range Equal to the suitable for battery operation. These types were designed to Supply Voltage directly interface with TTL and CMOS. • Maximum Input Offset Voltage (VIO) Type CA139A, has a lower input offset voltage than the - CA139A . 2mV CA139. Some of the SOIC parts are available on tape and - CA139, CA239, CA339. 5mV reel (see Ordering Information table). Replace the M suffix in - LM2901. 7mV the part number with M96 when ordering (e.g., - LM3302. 20mV CA0239M96). • Replacement for Industry Types 139, 239, 339, 139A, 2901, 3302
Ordering Information TEMP. Applications RANGE PKG. PART NO. (BRAND) (oC) PACKAGE NO.
• Square Wave Generator CA0139E -55 to 125 14 Ld PDIP E14.3 • Time Delay Generators CA0139M, AM (139, 139A) -55 to 125 14 Ld SOIC M14.15 • Pulse Generators CA0239E -25 to 85 14 Ld PDIP E14.3 CA0239M96 (239) -25 to 85 14 Ld SOIC M14.15 • Multivibrators CA0339E 0 to 70 14 Ld PDIP E14.3 • High Voltage Digital Logic Gates CA0339M (339) 0 to 70 14 Ld SOIC M14.15 • A/D Converters LM339N 0 to 70 14 Ld PDIP E14.3 • MOS Clock Timers LM2901N -40 to 85 14 Ld PDIP E14.3 LM3302M96 (3302) -40 to 85 14 Ld SOIC M14.15
Schematic Diagram
LM3302N -40 to 85 14 Ld PDIP E14.3
V+ 3 TO 2, 3, 4 Pinout 3.5
µ
A 100
µ
A 3.5
µ
A 100
µ
A CA139A (SOIC) CA139, CA339, LM3302 (PDIP, SOIC) CA239, LM2901, LM339 (PDIP)
TOP VIEW
+ INPUT Q Q 2 3 OUTPUT 5 Q Q 1 4 2 OUTPUT 2 1 14 OUTPUT 3 4 Q8 - INPUT OUTPUT 1 2 13 OUTPUT 4 Q5 Q6 Q7 TO 2, 3, 4 12 V+ 3 1 4 12 GND NEG. INPUT 1 4 11 POS. INPUT 4 COMPARATOR NO 1 + + + 7 11 9 POS. INPUT 1 5 10 NEG. INPUT 4 2 4 13 - 1 - 3 - 14 6 10 8 2 3 NEG. INPUT 2 6 9 POS. INPUT 3 POS. INPUT 2 7 8 NEG. INPUT 3
1 CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. 1-888-INTERSIL or 321-724-7143 | Copyright © Intersil Corporation 1999
