Datasheet LM339, LM339E, LM239, LM2901, LM2901E, LM2901V, NCV2901, MC3302 (ON Semiconductor) - 4
ManufacturerON Semiconductor
DescriptionSingle Supply Quad Comparators
Pages / Page11 / 4 — LM339, LM339E, LM239, LM2901, LM2901E, LM2901V, NCV2901, MC3302. …
Revision25
File Format / SizePDF / 165 Kb
LM339, LM339E, LM239, LM2901, LM2901E, LM2901V, NCV2901, MC3302. PERFORMANCE CHARACTERISTICS. LM2901/2901E/2901V
LM339, LM339E, LM239, LM2901, LM2901E, LM2901V, NCV2901, MC3302 PERFORMANCE CHARACTERISTICS LM2901/2901E/2901V
link to page 4 link to page 4 link to page 4 link to page 4 link to page 4
(VCC = +5.0 Vdc, TA = Tlow to Thigh [Note 7])
LM2901/2901E/2901V LM239/339/339E /NCV2901 MC3302 Characteristic Symbol Min Typ Max Min Typ Max Min Typ Max Unit
Input Offset Voltage (Note 8) VIO − − ±9.0 − − ±15 − − ±40 mVdc Input Bias Current (Notes 8, 9) IIB − − 400 − − 500 − − 1000 nA (Output in Analog Range) Input Offset Current (Note 8) IIO − − ±150 − − ±200 − − ±300 nA Input Common Mode Voltage Range VICMR 0 − VCC 0 − VCC 0 − VCC V −2.0 −2.0 −2.0 Saturation Voltage Vsat − − 700 − − 700 − − 700 mV VI(−) ≥ +1.0 Vdc, VI(+) = 0, Isink ≤ 4.0 mA Output Leakage Current IOL − − 1.0 − − 1.0 − − 1.0 mA VI(+) ≥ +1.0 Vdc, VI(−) = 0, VO = 30 Vdc Differential Input Voltage VID − − VCC − − VCC − − VCC Vdc All VI ≥ 0 Vdc 7. (LM239) Tlow = −25°C, Thigh = +85° (LM339, LM339E) Tlow = 0°C, Thigh = +70°C (MC3302) Tlow = −40°C, Thigh = +85°C (LM2901, LM2901E) Tlow = −40°C, Thigh = +105° (LM2901V & NCV2901) Tlow = −40°C, Thigh = +125°C NCV2901 is qualified for automotive use. 8. At the output switch point, VO ] 1.4 Vdc, RS ≤ 100 W 5.0 Vdc ≤ VCC ≤ 30 Vdc, with the inputs over the full common mode range (0 Vdc to VCC −1.5 Vdc). 9. The bias current flows out of the inputs due to the PNP input stage. This current is virtually constant, independent of the output state. + VCC + VCC R3 10 k R 10 k ref Vin - Vref Rref VO 10 k + V + CC R1 - VO R2 R2 V Vi + ref n 1.0 M 10 k V 10k R1 CC R1 V R3 V ref [ CC R1 R V ref + R1 ref = Rref + R1 1.0 M R3 ] R1 / / Rref / / R2 R2 [ R1 / / Rref R1 / / Rref V [V Amount of Hysteresis V H = O(max) - VO(min)] H R1/ / Rref + R2 R2 VH = [(V R2 ơ Rref / / R1 R2 + R3 O(max) - VO(min)]
Figure 2. Inverting Comparator Figure 3. Noninverting Comparator with Hysteresis with Hysteresis www.onsemi.com 4
