14 /8 — AD8213. Data Sheet. 2V/DIV. m (. NT RE. CUR. RCE U O. 0.01/DIV. UT P. UT …
Revision
D
PDF / 412 Kb
AD8213. Data Sheet. 2V/DIV. m (. NT RE. CUR. RCE U O. 0.01/DIV. UT P. UT O. IM AX. –40. –20. 100. 120. 140. TIME (5µs/DIV). TEMPERATURE (°C). 5.0 4.9 4.8
AD8213Data Sheet122V/DIVA)11m (10NT RE98CUR7RCE U O6S0.01/DIV5UT P4UT O3UM2IM AX1M0 05 1 –40–20020406080100120140 21 0 9- 9- TIME (5µs/DIV) 663 TEMPERATURE (°C) 63 0 06 Figure 16. Settling Time (Falling) Figure 19. Maximum Output Source Current vs. Temperature Per Channel 5.0 4.9 4.8)4.7V (2V/DIVE4.6 4.5RANG4.4E G4.3A T4.20.01/DIVL O4.1V4.0UT P3.9UT O3.8 3.7 3.6 3.5 06 1 0 0.5 1.0 1.5 2.0 2.5 3.0 3.5 4.0 4.5 5.0 5.5 6.0 6.5 7.0 7.5 23 0 9- 9- TIME (5µs/DIV) 663 OUTPUT SOURCE CURRENT (mA) 63 0 06 Figure 17. Settling Time (Rising) Figure 20. Output Voltage Range vs. Output Source Current Per Channel 122.011)A)V1.8m10(ND (1.6NT9G M1.4RRE8RO F E71.2INK CU S61.0RANGUTEP50.8AGUTT4LOO0.6UM3VIMUT0.42PAX MUT10.2O00–40–20020406080100120140 20 24 0 012345678910 0 9- 9- TEMPERATURE (°C) 63 OUTPUT SINK CURRENT (mA) 63 06 06 Figure 18. Maximum Output Sink Current vs. Temperature Figure 21. Output Voltage Range from GND vs. Output Sink Current Per Channel Per Channel Rev. D | Page 8 of 14 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION APPLICATION NOTES OUTPUT LINEARITY LOW-PASS FILTERING APPLICATIONS INFORMATION HIGH-SIDE CURRENT SENSE WITH A LOW-SIDE SWITCH HIGH-SIDE CURRENT SENSING LOW-SIDE CURRENT SENSING BIDIRECTIONAL CURRENT SENSING OUTLINE DIMENSIONS ORDERING GUIDE AUTOMOTIVE PRODUCTS
