link to page 11 link to page 13 Data SheetADL5310PIN CONFIGURATION AND FUNCTION DESCRIPTIONSMMFZG1EDMMETRROONUVVCCVO432102222921VSUM 118 SCL1INP1 217 BIN1ADL5310IRF1 316 LOG1DUAL LOG AMPIRF2 415 LOG2TOP VIEWINP2 5(Not to Scale)14 BIN2VSUM 613 SCL278901 11 21FSSGG2EOOEETRPPNNUVVVVVO 2 NOTES 00 1. EXPOSED PAD. THE EXPOSED PAD MUST -0- BE CONNECTED TO ANALOG GROUND 415 VIA A LOW IMPEDANCE PATH. 04 Figure 2. 24-Lead LFCSP Pin Configuration Table 3. Pin Function Descriptions Pin No.MnemonicFunction 1, 6 VSUM Guard Pin. Used to shield the INP1 and INP2 input current lines, and for optional adjustment of the input summing node potentials. Pin 1 and Pin 6 are internally shorted. 2 INP1 Channel 1 Numerator Input. Accepts (sinks) photodiode current IPD1. Usually connected to photodiode anode such that photocurrent flows into INP1. 3 IRF1 Channel 1 Denominator Input. Accepts (sinks) reference current, IRF1. 4 IRF2 Channel 2 Denominator Input. Accepts (sinks) reference current, IRF2. 5 INP2 Channel 2 Numerator Input. Accepts (sinks) photodiode current IPD2. Usually connected to photodiode anode such that photocurrent flows into INP2. 7, 24 VREF Reference Output Voltage of 2.5 V. Pin 7 and Pin 24 are internally shorted. 8, 9 VPOS Positive Supply, (VP – VN) ≤ 12 V. Both pins must be connected externally. 10, 11, 20 VNEG Optional Negative Supply, VN. These pins are usually grounded. For more details, see the General Structure and Applications Information sections. All VNEG pins must be connected externally. 12 OUT2 Buffer Output for Channel 2. 13 SCL2 Buffer Amplifier Inverting Input for Channel 2. 14 BIN2 Buffer Amplifier Noninverting Input for Channel 2. 15 LOG2 Output of the Logarithmic Front End for Channel 2. 16 LOG1 Output of the Logarithmic Front End for Channel 1. 17 BIN1 Buffer Amplifier Noninverting Input for Channel 1. 18 SCL1 Buffer Amplifier Inverting Input for Channel 1. 19 OUT1 Buffer Output for Channel 1. 21, 22 COMM Analog Ground. Pin 21 and Pin 22 are internally shorted. 23 VRDZ Intercept Shift Reference Input. The top of a resistive divider network that offsets VLOG to position the intercept. Normally connected to VREF; may also be connected to ground when bipolar outputs are to be provided. EPAD Exposed Pad. The exposed pad must be connected to analog ground via a low impedance path. Rev. B | Page 5 of 20 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS GENERAL STRUCTURE THEORY MANAGING INTERCEPT AND SLOPE RESPONSE TIME AND NOISE CONSIDERATIONS APPLICATIONS INFORMATION CALIBRATION MINIMIZING CROSSTALK RELATIVE AND ABSOLUTE POWER MEASUREMENTS CHARACTERIZATION METHODS EVALUATION BOARD OUTLINE DIMENSIONS ORDERING GUIDE
