Datasheet ZMOD4510 (IDT)
ManufacturerIDT
DescriptionOutdoor Air Quality Sensor Platform
Pages / Page16 / 1 — Gas Sensor Module for. ZMOD4510. Outdoor Air Quality. Datasheet. …
Revision20190909
File Format / SizePDF / 528 Kb
Gas Sensor Module for. ZMOD4510. Outdoor Air Quality. Datasheet. Description. Features. Typical Applications
Datasheet ZMOD4510 IDT, Revision: 20190909
Gas Sensor Module for ZMOD4510 Outdoor Air Quality Datasheet Description Features
The ZMOD4510 Gas Sensor Platform detects outdoor air quality in  Measurement of outdoor air quality, including ppb trace gas a variety of indoor and outdoor applications. The module is a 12- concentrations of nitrogen oxides (NOx) and ozone (O3) pin LGA assembly (3.0  3.0  0.7 mm) that consists of a gas  Supports international standards for total outdoor air quality, sense element and a CMOS signal conditioning IC. The module’s such as the US Environmental Protection Agency (EPA) sense element consists of a heater element on a silicon-based  MEMS structure and a metal-oxide (MOx) chemiresistor. The Heater driver and regulation loop for constant resistance, minimizing effect of environmental temperature on signal signal conditioner controls the sensor temperature and measures the MOx conductivity, which is a function of the gas concentration.  Internal auto-compensated temperature sensor; not stress sensitive The sensor module is optimized for the detection of trace atmospheric gases, including nitrogen oxides (NO  I2C interface: up to 400kHz x) and ozone (O3). The ZMOD4510 is targeted for monitoring the Total Outdoor  Configurable alarm/interrupt output with static and adaptive Air Quality giving an Air Quality Index (AQI). levels The measurement results can be read via an I2C interface with the  Built-in nonvolatile memory (NVM) for user data user’s microprocessor, which processes the data to determine the  Low average power consumption in low mW range levels of gases present and to indicate the AQI based on  Supports low-voltage and low-power battery applications international standards. With its low operating current, the ZMOD4510 is an excellent choice for low-voltage and low-power  No external trimming components required battery applications. Built-in nonvolatile memory (NVM) stores the  External reset pin (active-LOW) configuration and provides space for arbitrary user data.  Customization for mobile, industrial, and consumer applications
 Siloxane resistant  Outdoor air monitoring  Detect unhealthy conditions in outdoor air
ZMOD4510 Application Circuit
 Personal air quality monitors  Automation based on AQI (HVAC systems, building air VSUPPLY VSS VSS purification systems) Power VDDIO Supply VDDH
Physical Characteristics
VDD  Target operation temperature: -40°C to 65°C  Supply voltage: 1.7V to 3.6V
ZMOD4510
 Package: 12-LGA
Gas Sensor Module
SDA SCL  Assembly size: 3.0  3.0  0.7 mm Algorithms Post-Processing INT RES_N
Available Support
 ZMOD4510 Evaluation Kit  Manuals, application notes, blog, and white papers  Instructional videos  Programming libraries, example codes, and algorithm support to optimize performance © 2019 Integrated Device Technology, Inc. 1 September 9, 2019 Document Outline 1. Pin Assignments 2. Pin Descriptions 3. Absolute Maximum Ratings 4. Operating Conditions 5. Electrical Characteristics 6. Block Diagram 7. Sensor Module Characteristics 7.1 Gas Sensor Module Characteristics 7.2 Internal Temperature Sensor Characteristics 8. Gas Sensor Module Characteristics 8.1 Typical Gas Stimulation 8.2 Environmental Temperature and Humidity 8.3 Accuracy and Conditioning 9. Assembly Restrictions, Operation, Integration Notes, and Storage 10. Test and Calibration 11. I2C Interface and Data Transmission Protocol 12. Related Websites and Software 13. Glossary 14. Package Outline Drawings 15. Marking Diagram 16. Ordering Information 17. Revision History
