Datasheet TB67S158FTG (Toshiba) - 6
ManufacturerToshiba
DescriptionBi-CD Integrated Circuit Silicon Monolithic
Pages / Page32 / 6 — 3-3. Pin description of the TB67S158 (QFN48)
3-3 Pin description of the TB67S158 (QFN48)
TB67S158FTG
Pin No. Full parallel CLK Serial/Parallel Large (MODE0=L,MODE1=L) (MODE0=H,MODE1=L) (MODE0=L,MODE1=H) (MODE0=H,MODE1=H) 1 NC NC NC NC 2 OUT_D+ ON pin Setting pin (1_CD) of motor excitation system Input pin for serial data NC 3 OUT_D- ON pin Setting pin (2_CD) of motor excitation system Input pin for serial clock NC 4 OUT_C+ ON pin Setting pin (1_AB ) of motor Output pin for rising temperature Setting pin (1 ) of motor excitation system detection excitation system 5 OUT_C- ON pin Setting pin (2_AB) of motor excitation system NC Setting pin (2 ) of motor excitation system 6 OUT_A+ ON pin Setting pin (_AB) for rotating direction Clear pin for storage register Setting pin for rotating direction 7 NC NC NC NC 8 OUT_A- ON pin Reset pin (AB) of electrical angle Clear pin for storage register Reset pin of electrical angle 9 OUT_B+ ON pin ON/OFF setting pin (_AB ) for motor output Standby setting pin ON/OFF setting pin for motor output 10 OUT_B- ON pin CLK Input pin (_AB) Input pin for serial latch CLK Input pin 11 NC NC NC NC 12 NC NC NC NC 13 NC NC NC NC 14 Output + pin for phase A Output + pin for phase A Output + pin for phase A Output + pin for phase A 15 Output + pin for phase A Output + pin for phase A Output + pin for phase A Output + pin for phase A 16 Output - pin for phase A Output - pin for phase A Output - pin for phase A Output - pin for phase A 17 Output - pin for phase A Output - pin for phase A Output - pin for phase A Output - pin for phase A 18 Power ground pin Power ground pin Power ground pin Power ground pin 19 Power ground pin Power ground pin Power ground pin Power ground pin 20 Output - pin for phase B Output - pin for phase B Output - pin for phase B Output - pin for phase B 21 Output - pin for phase B Output - pin for phase B Output - pin for phase B Output - pin for phase B 22 Output + pin for phase B Output + pin for phase B Output + pin for phase B Output + pin for phase B 23 Output + pin for phase B Output + pin for phase B Output + pin for phase B Output + pin for phase B 24 Common pin for phase A and B Common pin for phase A and B Common pin for phase A and B Common pin for phase A and B 25 Switching pin for I/F MODE Switching pin for I/F MODE Switching pin for I/F MODE Switching pin for I/F MODE (L setting) (H setting) (L setting) (H setting) 26 Switching pin for I/F MODE Switching pin for I/F MODE Switching pin for I/F MODE Switching pin for I/F MODE (L setting) (L setting) (H setting) (H setting) 27 NC Setting pin (_CD) for rotating direction NC NC 28 NC Input pin (_CD) for CLK NC NC 29 NC NC NC NC 30 Pin for main power supply Pin for main power supply Pin for main power supply Pin for main power supply 31 NC NC NC NC 32 NC ON/OFF setting pin (_CD ) for motor output NC NC 33 NC Reset pin (AB) of electrical angle NC NC 34 Output pin for abnormal Output pin for abnormal Output pin for abnormal Output pin for abnormal detection detection detection detection 35 Logic ground pin Logic ground pin Logic ground pin Logic ground pin 36 NC NC NC NC 37 Common pin for phase C and D Common pin for phase C and D Common pin for phase C and D Common pin for phase C and D 38 Output + pin for phase D Output + pin for phase D Output + pin for phase D Output + pin for phase D 39 Output + pin for phase D Output + pin for phase D Output + pin for phase D Output + pin for phase D 40 Output - pin for phase D Output - pin for phase D Output - pin for phase D Output - pin for phase D 41 Output - pin for phase D Output - pin for phase D Output - pin for phase D Output - pin for phase D 42 Power ground pin Power ground pin Power ground pin Power ground pin 43 Power ground pin Power ground pin Power ground pin Power ground pin 44 Output - pin for phase C Output - pin for phase C Output - pin for phase C Output - pin for phase C 45 Output - pin for phase C Output - pin for phase C Output - pin for phase C Output - pin for phase C 46 Output + pin for phase C Output + pin for phase C Output + pin for phase C Output + pin for phase C 47 Output + pin for phase C Output + pin for phase C Output + pin for phase C Output + pin for phase C 48 NC NC NC NC 6 2015-3-3
