Datasheet TSSP950 (Vishay) - 9
ManufacturerVishay
DescriptionIR Sensor Module for Reflective Sensor, Light Barrier, and Fast Proximity Applications
Pages / Page11 / 9 — TSSP950.. VISHAY SEMICONDUCTORS GmbH STANDARD BAR CODE PRODUCT LABEL. …
File Format / SizePDF / 360 Kb
TSSP950.. VISHAY SEMICONDUCTORS GmbH STANDARD BAR CODE PRODUCT LABEL. PLAIN WRITING. ABBREVIATION. LENGTH. LONG BAR CODE TOP. TYPE
TSSP950. VISHAY SEMICONDUCTORS GmbH STANDARD BAR CODE PRODUCT LABEL PLAIN WRITING ABBREVIATION LENGTH LONG BAR CODE TOP TYPE
TSSP950..
(finished goods)
Item-description - 18 Item-number INO 8 Selection-code SEL 3 LOT-/serial-number BATCH 10 Data-code COD 3 (YWW) Plant-code PTC 2 Quantity QTY 8 Accepted by ACC - Packed by PCK - Mixed code indicator MIXED CODE - Origin xxxxxxx+ Company logo
LONG BAR CODE TOP TYPE LENGTH
Item-number N 8 Plant-code N 2 Sequence-number X 3 Quantity N 8 Total length - 21
SHORT BAR CODE BOTTOM TYPE LENGTH
Selection-code X 3 Data-code N 3 Batch-number X 10 Filter - 1 Total length - 17
DRY PACKING
After more than 72 h under these conditions moisture The reel is packed in an anti-humidity bag to protect the content will be too high for reflow soldering. devices from absorbing moisture during transportation and In case of moisture absorption, the devices will recover to storage. the former condition by drying under the following condition: Aluminum bag 192 h at 40 °C + 5 °C / - 0 °C and < 5 % RH (dry air / nitrogen) or 96 h at 60 °C + 5 °C and < 5 % RH for all device containers Label or 24 h at 125 °C + 5 °C not suitable for reel or tubes. An EIA JEDEC® standard J-STD-020 level 4 label is included on all dry bags. Reel
LEVEL CAUTION
This bag contains
4 MOISTURE-SENSITIVE DEVICES
15973 1. Shelf life in sealed bag: 12 months at < 40 °C and < 90 % relative
FINAL PACKING
humidity (RH) 2. After this bag is opened, devices that will be subjected to soldering reflow or equivalent processing (peak package body temp. 260 °C) The sealed reel is packed into a cardboard box. must be 2a. Mounted within 72 hours at factory condition of < 30 °C/60 % RH or 2b. Stored at < 5 % RH 3. Devices require baking befor mounting if:
RECOMMENDED METHOD OF STORAGE
Humidity Indicator Card is > 10 % when read at 23 °C ± 5 °C or 2a. or 2b. are not met. 4. If baking is required, devices may be baked for: Dry box storage is recommended as soon as the aluminum 192 hours at 40 °C + 5 °C/- 0 °C and < 5 % RH (dry air/nitrogen) or 96 hours at 60 °C ± 5 °C and < 5 % RH for all device containers or bag has been opened to prevent moisture absorption. The 24 hours at 125 °C ± 5 °C not suitable for reels or tubes Bag Seal Date: following conditions should be observed, if dry boxes are (If blank, see barcode label) not available:
Note: Level and body temperature defined by EIA JEDEC Standard J-STD-020
22522 • Storage temperature 10 °C to 30 °C EIA JEDEC standard J-STD-020 level 4 label is included • Storage humidity ≤ 60 % RH max. on all dry bags Rev. 1.1, 17-Apr-2019
9
Document Number: 82867 THIS DOCUMENT IS SUBJECT TO CHANGE WITHOUT NOTICE. THE PRODUCTS DESCRIBED HEREIN AND THIS DOCUMENT ARE SUBJECT TO SPECIFIC DISCLAIMERS, SET FORTH AT www.vishay.com/doc?91000
