Datasheet IS2083 (Microchip) - 7
Manufacturer | Microchip |
Description | Bluetooth Stereo Audio SoC |
Pages / Page | 65 / 7 — IS2083. Quick References. ...continued. Acronyms/Abbreviations. … |
File Format / Size | PDF / 2.9 Mb |
IS2083. Quick References. ...continued. Acronyms/Abbreviations. Description. Datasheet
IS2083 Quick References ...continued Acronyms/Abbreviations Description
DPSK Differential Phase Shift Keying DQPSK Differential Quadrature Phase Shift Keying DR Receive Data DSP Digital Signal Processor DT Transmit Data EDR Enhanced Data Rate EMC Electromagnetic Compatibility EVB Evaluation Board FET Field Effect Transistor GAP General Access Profile GATT General Attribute Profile GFSK Gaussian Frequency Shift Keying GPIO General Purpose Input Output GUI Graphical User Interface HFP Hands-free Profile HPF High Pass Filter HSP Headset Profile HW Hardware I2C Inter-Integrated Circuit I2S Inter-IC Sound IC Integrated Circuit ICSP In-Circuit Serial Programming IDE Integrated Development Environment IF Intermediate Frequency IPE Integrated Programming Environment JTAG Joint Test Action Group LDO Low-Dropout LED Light Emitting Diode LNA Low-Noise Amplifier LPA Linear Power Amplifier LSB Least Significant Bit MAC Medium Access Control MB DRC Multiband Dynamic Range Compression MCLK Master Clock MCU Microcontroller MEMS Micro-Electro-Mechanical Systems MFB Multi-function Button Modem Modulator-demodulator MPA Medium Power Amplifier mSBC Modified Sub-band Coding © 2019 Microchip Technology Inc.
Datasheet
DS70005403B-page 7 Document Outline Introduction Features Table of Contents 1. Quick References 1.1. Reference Documentation 1.2. Acronyms/Abbreviations 2. Device Overview 2.1. IS2083BM Device Ball Diagram 2.2. IS2083BM Device Ball Description 3. Audio Subsystem 3.1. Digital Signal Processor 3.2. Codec 3.2.1. Audio Performance 3.3. Auxiliary Port 3.4. Microphone Inputs 3.5. Analog Speaker Output 4. Bluetooth Transceiver 4.1. Transmitter 4.2. Receiver 4.3. Synthesizer 4.4. Modulator-Demodulator 4.5. Adaptive Frequency Hopping 5. Microcontroller 5.1. Memory 5.2. Clock 6. Power Management Unit 6.1. Device Operation 6.2. Power Supply 6.3. Adapter Input 6.4. Buck1 (BK1) Switching Regulator 6.5. Buck2 (BK2) Switching Regulator 6.6. Low-Droput Regulator 6.7. Battery Charging 6.7.1. Battery Charger Detection 6.8. SAR ADC 6.9. LED Driver 7. Application Information 7.1. Power On/Off Sequence 7.2. Reset 7.3. Programming and Debugging 7.3.1. Test Mode 7.3.2. Flash Memory and SQI Controller 7.3.2.1. SQI Controller 7.3.3. 2-wire Interface 7.3.3.1. Serial Program Clock 7.3.3.2. Serial Program Data 7.3.4. Enabling Programming Interface 7.3.5. On-chip Instrumentation 7.3.5.1. Enabling OCI Functionality 7.3.5.2. Entering Debug Mode 7.3.5.3. Reading the Debug Status 7.3.5.4. Reading the Program Counter 7.3.5.5. Stopping Program Execution (Entering Debug Mode) 7.3.5.6. Starting Program Execution (Exiting Debug Mode) 7.3.5.7. User Single Step Mode 7.3.5.8. OCI Single Step Mode 7.3.5.9. Setting Software Breakpoints 7.3.5.10. Simple and Complex Debug Triggers 7.3.5.11. Reading and Writing Memory/SFR Registers 7.3.5.12. Trace Buffer 7.3.5.13. Instruction Trace 7.4. General Purpose I/O Pins 7.5. I2S Mode Application 7.6. Host MCU Interface 8. Electrical Specifications 8.1. Timing Specifications 9. Package Information 10. Ordering Information 11. Document Revision History The Microchip Website Product Change Notification Service Customer Support Microchip Devices Code Protection Feature Legal Notice Trademarks Quality Management System Worldwide Sales and Service
