Datasheet NLM0011 / NLM0010 NFC-PWM Series (Infineon) - 4
ManufacturerInfineon
DescriptionNFC Wireless Configuration IC with PWM Output
Pages / Page35 / 4 — NLM0011/ NLM0010 " NFC-PWM Series ". NFC Wireless Configuration …
Revision02_00
File Format / SizePDF / 511 Kb
NLM0011/ NLM0010 " NFC-PWM Series ". NFC Wireless Configuration IC with PWM Output. 2 Feature Overview
NLM0011/ NLM0010 " NFC-PWM Series " NFC Wireless Configuration IC with PWM Output 2 Feature Overview
NLM0011/ NLM0010 " NFC-PWM Series " NFC Wireless Configuration IC with PWM Output 2 Feature Overview 2 Feature Overview
NLM0011/NLM0010 product features are given here.
Product Features Contactless Interface
• Physical interface and Anti collision compliant to ISO/ IEC 18000-3 mode 1 (ISO/IEC 15693) - contactless transmission of data and supply energy - data rate up to 26.69 kbit/s - operation frequency: 13.56 MHz - Anti-collision method complying with ISO/IEC 18000-3 mode 1 with identification rate of up to 50 tags/s • AFI according ISO/IEC 18000-3 mode 1 • Read / write distance up to 150 cm (influenced by external circuitry i.e. reader and antenna design)
Command Set
• Support of error codes 01H, 0FH, 10H, 12H according to ISO/ IEC 18000-3 mode 1 • If a command is sent to the NLM0011/NLM0010 which has an invalid frame length no response is returned • Following command set is supported: - Inventory (command code 01H) - StayQuiet (command code 02H) - ReadSingleBlock (command code 20H) - WriteSingleBlock (command code 21H) - Select (command code 25H) - ResetToReady (command code 26H) - WriteAFI (command code 27H) - LockAFI (command code 28H) - WriteByte (custom command - ISO command code A0H; custom embedded command code 90H)
Non Volatile Memory (NVM)
An Infineon EEPROM is used. • size 576 Bit • User area 52 bytes, organized in 13 free user blocks • Each block organized in 4 bytes • Service area 12 bytes • Unique chip identification number • Each block can be permanently locked against overwriting • EEPROM programming time per page < 4 ms • EEPROM endurance minimum 100,000 erase/write cycles • Data retention minimum 10 years
Supply Concept
operation mode dependent: • in Lighting Operation mode the chip is supplied by external voltage source - external supply voltage in the range of 3 … 5V - internal voltage regulator (LDO) is generating a stabilized internal supply - if external supply voltage is present, then the device cannot be supplied by harvesting energy from the NFC field Datasheet 4 2.0 2019-05-31 Document Outline Features Description Table of contents 1 General 2 Feature Overview 3 Application Overview 4 Pin Description 5 Functional Description 6 Memory Organization 7 Application and User Memory Access Control 8 NLM0011/NLM0010 EEPROM Shipment Content (Infineon to Customer) 9 Constant Lumen Output (CLO) and Operating Time Counting (OTC) 10 PWM Overview 11 NLM0011/ NLM0010 Command Set 12 NLM0011/ NLM0010 Electrical Characteristics 13 Package Outline Revision history Disclaimer
